Hello, first of all, I would like to say that I have purchased tons of official arduino boards, but I hate reusing the boards from project to project so I thought I could buy a few clones for ~$3 each. I purchased this pro mini clone: http://www.ebay.com/itm/200957063666. However, when I try to upload a sketch to it via a FTDI board it give an error "avrdude: stk500_recv(): programmer is not responding"? I know the FTDI board works fine with my other official pro mini arduino.
I connected the clone to my arduino uno like this diagram http://arduino.cc/en/uploads/Tutorial/arduinoisp.png and got it to upload the sketch to the clone via the uno. That works but it's a pain in the butt.
Does anyone have any idea why the FTDI doesn't work?
Thanks! Tyler
Remember that once you have use an ISP to upload a sketch you have wiped out the bootloader and can no longer upload through serial. To fix that you have to upload a fresh bootloader.
Maybe the board did not have a good bootloader when you got it. Try uploading the Arduino Pro Mini bootloader and then trying the FTDI cable again.
johnwasser: Remember that once you have use an ISP to upload a sketch you have wiped out the bootloader and can no longer upload through serial. To fix that you have to upload a fresh bootloader.
Thanks I did not know that. I uploaded a new boot loader via the uno and still the FTDI does not work. Also when I connect the FTDI, the board flashes about 20 times a second but if I jumper the VCC from the header to the VCC on the board it goes back to flashing once a second.
I am thinking it is a problem with some of the pins. When I use my multimeters continuity testing it says that the RXI pin is connected to the VCC pin. But not the VCC on the header. I made a pic showing what pin is connected to what.
Thanks! Tyler
Edit: By the way, on the back of the board it says "Deek-Robot"
RXI should definitely not be shorted to VCC. Examine both traces under magnification to see if you can find the short.
johnwasser: RXI should definitely not be shorted to VCC. Examine both traces under magnification to see if you can find the short.
Yeah, that is what I was thinking. But I've looked at the board and I can't find anywhere on the board where the RXI is even close to VCC?
Thanks Tyler
MrPenguin9: I've looked at the board and I can't find anywhere on the board where the RXI is even close to VCC?
What about that surface-mount device next to the words "Pro mini"? it has RXI connected to one end and VCC connected to the other. Perhaps it is shorted?
