Hi!
I saw all of posts here with the same title, but i still get this error...
So, few details about my problem:
arduino pro mini AtMega328 5v 16Mhz, connect with usb-uart
if connect to mac (v.10.16.6) - can't find port, so I decide run on virtual windows 7.
On win7 use ArduinoIDE 1.6.9
Board - ArduinoPro or Pro Mini
Port - com4 (the same as in deviceManager)
Compilation - ok
but then get an error. here is stackTrace:
avrdude: Version 6.3, compiled on Sep 12 2016 at 17:24:16
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Users\Admin\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino6/etc/avrdude.conf"
Using Port : COM4
Using Programmer : arduino
Overriding Baud Rate : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xfb
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xfb
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xfb
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xfb
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xfb
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xfb
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xfb
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xfb
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xfb
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xfb
avrdude done. Thank you.
Please, any idea?
Thanks!
