Hi all,
After months of good use, both my boards Mega 2560 and Uno became unavailable for uploading sketch or burning bootloader.
Sketch uses 444 bytes (1%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\[...]bin/avrdude -CC:[...]avrdude\6.3.0-arduino9/etc/avrdude.conf -v -patmega328p -cstk500v1 -PCOM5 -Uflash:w:C:\Users\GREGOR~1\AppData\Local\Temp\arduino_build_242793/BareMinimum.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "C:[...]\arduino\tools\avrdude\6.3.0-arduino9/etc/avrdude.conf"
         Using Port                    : COM5
         Using Programmer              : stk500v1
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x03
Facts :
  • v1.6.20 of the boards
  • v1.8.5 of the IDE
  • Windows 8.1 64bits
  • Programmer: "AVR ISP"
  • Drivers are fine (the boards are well recognized)
  • Serial monitor works
  • I'm trying to upload the "Bare minimum" exemple sketch
  • Nothing in pin 0 and 1, nothing at all is plugged actually
  • Get Board info:
  • Uno : VID 2A03
  • Mega2560 : VID 2A03
What i tried :
Nothing works. If you have any idea.....
Thank you all !
Same here!
Ive got the same problem! If you find a solution please tell me!
It actually worked when I tried just “upload” (ctrl+U) and not “upload with controller” (ctrl+shift+U).
I know now where the problem comes from…
