Hi Everyone.
I had the same issue mentioned on this topic. and I have found a solution to this.
This problem is caused by manufacturer. Instead of a FT232 IC, they have used CH340 IC. The driver installed with the Arduino IDE is compatible with FT232. In order to solve this problem just download and install the Serial USB Driver for CH340 and you should see a new COM appear in the port menu. I used the old bootloader option for processor in Arduino IDE. With all this done, I could successfully upload the blink example to my Arduino Nano.
Link to CH340 Driver: USB Serial Driver Quick Install - learn.sparkfun.com
Arduino: 1.8.16 (Mac OS X), Board: "Arduino Uno"
Sketch uses 924 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
/Users/christyyau/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/bin/avrdude -C/Users/christyyau/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.usbmodem11201 -b115200 -D -Uflash:w:/var/folders/b3/y_g3drns0rn7hml6sn82s3jr0000gn/T/arduino_build_400066/sketch_sep09a.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
     System wide configuration file is "/Users/christyyau/Library/Arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf"
     User configuration file is "/Users/christyyau/.avrduderc"
     User configuration file does not exist or is not a regular file, skipping
An error occurred while uploading the sketch
     Using Port                    : /dev/cu.usbmodem11201
     Using Programmer              : arduino
     Overriding Baud Rate          : 115200
avrdude: ser_open(): can't open device "/dev/cu.usbmodem11201": No such file or directory
avrdude done. Thank you.
option enabled in File -> Preferences.
I have no idea about Macs.
Does /dev/cu.usbmodem11201 disappear from the IDE's port options when you disconnect the board?
The Mac should have tools that can show you what is going on under the hood. Under Linux, it would be dmesg and lsusb; do they exist on a Max?
I know this is an old thread. But I had this problem yesterday - it would upload the first time and then all subsequent uploads errored out. Had to reconnect the usb and/or restart the IDE. After having seen some threads on the forum, I uninstalled the driver (the default one), installed the latest IDE version and cancelled the automatic driver search on windows update thereby allowing it to install the bundled driver.
That said, the problem started all of a sudden - it was working fine with the default driver till yesterday. I think it has something to do with repeated uploads - I had been uploading the code repeatedly to test changes.
*Check the chord
*Change the port
*Disable antivirus
*Go to TOOLS> processor > select “ATmega168”
*Check the chord
*Change the port
*Disable antivirus
can someone help me i have a problem wile burning bootloader on 3d printer motherboard exacly anet3d v1.7 and this error ocures:
Arduino:1.8.16 (Windows 10), Płytka:"Sanguino, ATmega1284 or ATmega1284P (16 MHz)"
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega1284p -cstk500v1 -PCOM3 -b19200 -e -Ulock:w:0x3F:m -Uefuse:w:0xFD:m -Uhfuse:w:0xDE:m -Ulfuse:w:0xFF:m
     System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
     Using Port                    : COM3
     Using Programmer              : stk500v1
     Overriding Baud Rate          : 19200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xff
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xff
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xff
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xff
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xff
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xff
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xff
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xff
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xff
Błąd przy wgrywaniu bootloadera.
Even I face this especially when doing frequent code uploads in one session. Seems to be a USB issue on the host device (computer), and I think maybe the OS has something to do with it. Simple workaround is to disconnect the board from USB, close the arduino IDE and reconnect, restart...
Arduino: 1.8.16 (Windows 10), Board: "Arduino Nano, ATmega328P"
Sketch uses 924 bytes (3%) of program storage space. Maximum is 30720 bytes.
C:\Users\karim\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/bin/avrdude -CC:\Users\karim\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -PCOM5 -b115200 -D -Uflash:w:C:\Users\karim\AppData\Local\Temp\arduino_build_773560/Blink.ino.hex:i
     System wide configuration file is "C:\Users\karim\AppData\Local\Arduino15\packages\arduino\tools\avrdude\6.3.0-arduino17/etc/avrdude.conf"
     Using Port                    : COM5
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xc5
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xc5
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xc5
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xc5
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xc5
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xc5
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xc5
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xc5
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xc5
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xc5
Problem uploading to board. See https://support.arduino.cc/hc/en-us/sections/360003198300 for suggestions.
Hi @karima8. Select Tools > Processor > ATmega328P (Old Bootloader) from the Arduino IDE's menus and then try uploading again.
i just tried that and still the same problem. i must to add that i changed fusebits befor burning bootloader, i changed from internal to external oscilator and I thing it must be connected with this
Arduino: 1.8.17 Hourly Build 2021/09/06 02:33 (Windows 10), Board: "Arduino Uno"
Sketch uses 1910 bytes (5%) of program storage space. Maximum is 32256 bytes.
E:\BACKUP-APRIL 15 2021\DLT FILES(ALBERT QUITORAS)\arduino-nightly-windows\arduino-nightly\hardware\tools\avr/bin/avrdude -CE:\BACKUP-APRIL 15 2021\DLT FILES(ALBERT QUITORAS)\arduino-nightly-windows\arduino-nightly\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM1 -b115200 -D -Uflash:w:C:\Users\admin\AppData\Local\Temp\arduino_build_79670/blind_stick.ino.hex:i
         System wide configuration file is "E:\BACKUP-APRIL 15 2021\DLT FILES(ALBERT QUITORAS)\arduino-nightly-windows\arduino-nightly\hardware\tools\avr/etc/avrdude.conf"
         Using Port                    : COM1
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x03
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x03
Hello @albertquitoras.
Remove any connections to pins 0 and 1 on your Arduino board. These pins are used for communication with your computer, including uploads. Connecting anything to these pins can interfere with uploads.
Make sure you have the correct board selected from the Arduino IDE's Tools > Board menu. Note that some boards have similar names, but are not interchangeable. Examples include "Arduino Uno" vs. "Arduino Uno WiFi" vs. "Arduino Uno WiFi Rev2", "Arduino Nano" vs. "Arduino Nano Every" vs. "Arduino Nano IoT" vs "Arduino Nano 33 BLE" vs. "Arduino Nano RP2040 Connect", "Arduino Duemilanove" vs. "Arduino Due".
Make sure you have selected the port of your Arduino board from the Arduino IDE's Tools > Port menu.
Sometimes the port will be labeled with the board name in the menu. Other times it will not. If you don't know which port is your Arduino board, you can find it by doing this:
  1. Unplug your Arduino board from the computer.
  2. Select Tools > Port from the Arduino IDE's menus.
  3. Note the ports, if any, listed in the menu.
  4. Close the Tools menu.
    The ports list is only updated when the Tools menu is re-opened, so this step is essential.
  5. Plug your Arduino board into the computer.
  6. Select Tools > Port from the Arduino IDE's menus. - The new port listed in the menu is the one for your Arduino board.
Arduino: 1.8.16 (Windows 10), Board: "Arduino Nano, ATmega328P (Old Bootloader)"
Sketch uses 2914 bytes (9%) of program storage space. Maximum is 30720 bytes.
Global variables use 227 bytes (11%) of dynamic memory, leaving 1821 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM8 -b57600 -D -Uflash:w:C:\Users\abd_2\AppData\Local\Temp\arduino_build_776804/servo_460.ino.hex:i
         Using Port                    : COM8
         Overriding Baud Rate          : 57600
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xf9
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xf9
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xf9
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xf9
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xf9
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xf9
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xf9
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xf9
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xf9
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xf9
Hi @AbdullahBishtawi.
Select Tools > Processor > ATmega328P from the Arduino IDE's menus and then try uploading again.
Sketch uses 2786 bytes (8%) of program storage space. Maximum is 32256 bytes.
Global variables use 53 bytes (2%) of dynamic memory, leaving 1995 bytes for local variables. Maximum is 2048 bytes.
/Applications/Arduino.app/Contents/Java/hardware/tools/avr/bin/avrdude -C/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf -v -patmega328p -carduino -P/dev/cu.usbserial-1440 -b115200 -D -Uflash:w:/var/folders/ws/fwph2hzd3_q5h1d6w38pl6mc0000gn/T/arduino_build_797441/Robot_Code_4.ino.hex:i
         System wide configuration file is "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
         User configuration file is "/Users/annafrischmon/.avrduderc"
         Using Port                    : /dev/cu.usbserial-1440
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
Can you explain this error?
Its the host machine USB problem. Disconnect from USB, wait a few seconds and reconnect and wait a few seconds before uploading. I've been facing this for quite some time and there does not seem to be a permanent fix...
Hello @frisc141. I'll provide you with a list of things you can try to resolve this error:
