So I am currently using windows 10 and used Arduino which download through window store apps
My current board is
BN: Arduino/Genuino Uno
VID: 2341
PID: 0043
SN: 75735303031351209061
But before I post this problem I tried many different solutions such as reinstall, update drivers
Now my currently IDE shows the port but somehow is unable to upload
Using Programmer : arduino
Overriding Baud Rate : 115200
And the same thing happens
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xb9
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xb9
Remove any connections to pins 0 and 1. These pins are used for communication with your computer, including uploads. Connecting anything to these pins can interfere with uploads.
Make sure you have selected the port of your Arduino board from the Tools > Port menu.
Sometimes the port will be labeled with the board name in the menu. Other times it will not. If you don’t know which port is your Arduino, you can find it like this:
Unplug your Arduino board from the computer.
Tools > Port
Note the ports, if any, listed in the menu.
Close the Tools menu
Plug your Arduino board into the computer.
Tools > Port - The new port listed in the menu is your Arduino board.
If the Tools > Port menu is grayed or the port of your Arduino does not appear on the menu:
Make sure your USB cable is fully inserted into the Arduino board and the computer.
You may need to install the driver for the USB-serial chip on your Arduino.
You may be using a charge-only or defective USB cable. Try a different cable or test your cable on another device to confirm that it works for data.
Using a USB 3.0 port on your computer may cause problems. Try a USB 2.0 port.
