avrdude: stk500v2_ReceiveMessage(): timeout with ADDAC VCC module
Ubuntu 14.04 and arduino ide 1.0.5
Ideally I won't have to mess with the module... And I'm not a programmer...
Thanks!!
bumpity ??
Binary sketch size: 12,330 bytes (of a 258,048 byte maximum)
/usr/share/arduino/hardware/tools/avrdude -C/usr/share/arduino/hardware/tools/avrdude.conf -v -v -v -v -patmega2560 -cwiring -P/dev/ttyUSB0 -b115200 -D -Uflash:w:/tmp/build953252908946386724.tmp/comps.cpp.hex:i
avrdude: ser_recv(): programmer is not responding
avrdude: Send: . [1b] . [01] . [00] . [01] . [0e] . [01] . [14]
avrdude: Version 6.0.1, compiled on Oct 21 2013 at 17:07:18
         Copyright (c) 2007-2009 Joerg Wunsch
         System wide configuration file is "/usr/share/arduino/hardware/tools/avrdude.conf"
         User configuration file is "/home/luke/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : /dev/ttyUSB0
         Using Programmer              : wiring
         Overriding Baud Rate          : 115200
avrdude: wiring_open(): releasing DTR/RTS
avrdude: wiring_open(): asserting DTR/RTS
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude done.  Thank you.
