avrdude: stk500v2_ReceiveMessage(): timeout
I have a very strange behavior with my arduino mega 2560. All works fine except this simple code:
      Serial.print("!!!");
These three exclamation marks are the problem.
Can anyone reproduce the problem?
I have an arduino mega 2560. I use windows 7 64 bit with arduino-PR-2568-BUILD-156-windows
Very strange :-)
Here is the error output:
avrdude: writing flash (1744 bytes):
Writing | ##########################################avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: ser_send(): write error: sorry no info avail
Yes. !!! is your problem. The IDE, compiler or chip doesn't like it. Try !! and it will work.
ChilliTronix: Yes. !!! is your problem. The IDE, compiler or chip doesn't like it. Try !! and it will work.
Its the bootloader that kicks it out.
Thanks for testing. Ok, I will try a new bootloader.
Do you really really need the !!!? If not I would try not putting !!! in your code.
