Everything was and has been working awesome. The update Pop up came up and for the first time(newbeee) I picked "board"(think that was the choice?????) anyway the update window (very similar to the update window for libraries), i picked the update(cant recall exactly the name, but know it was AVR related) and now i get this communication error every time i try to upload. Can i uninstall the update? HELP!!!! Thanks
Please do this:
- File > Preferences > Show verbose output during: > compilation (uncheck) > upload (check) > OK
- Sketch > Upload
- After the upload fails you'll see a button on the right side of the orange bar "Copy error messages". Click that button.
- Paste the error messages in a reply here USING CODE TAGS (</> button on the forum toolbar).
Arduino: 1.8.11 (Windows 10), Board: "Arduino Nano, ATmega328P"
Sketch uses 20522 bytes (66%) of program storage space. Maximum is 30720 bytes.
Global variables use 521 bytes (25%) of dynamic memory, leaving 1527 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM8 -b115200 -D -Uflash:w:C:\Users\ze353709\AppData\Local\Temp\arduino_build_201475/ssd1306_128x64_i2c.ino.hex:i
avrdude: Version 6.3-20190619
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM8
Using Programmer : arduino
Overriding Baud Rate : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x05
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x05
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x05
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x05
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x05
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x05
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x05
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x05
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x05
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x05
avrdude done. Thank you.
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
royblessingchibwe:
Select Tools > Processor > ATmega328P (Old Bootloader) and then try uploading again.
Arduino: 1.8.13 (Windows 10), Board: "Arduino Uno"
Couldn't deeply cache core build: Rel:
Running normal build of the core...
Sketch uses 924 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM5 -b115200 -D -Uflash:w:D:\My Documents\Arduino\Hex/Blink.ino.hex:i
Using Port : COM5
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xd5
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xd5
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xd5
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xd5
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xd5
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xd5
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xd5
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xd5
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xd5
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xd5
My board is Arduino uno r3. It got the upload problem with window 7 and Arduino 1.8.13 a few days ago. The problem was solved when Arduino was downgraded to 1.0.
Sketch uses 944 bytes (2%) of program storage space. Maximum is 32256 bytes.
C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM3 -b115200 -D -Uflash:w:C:\Users\edenm\AppData\Local\Temp\arduino_build_333440/sketch_FirstSketch.ino.hex:i
Using Port : COM3
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xb5
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xb5
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xb5
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xb5
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xb5
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xb5
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xb5
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xb5
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xb5
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xb5
edom:
Remove any connections to pins 0 and 1 on your Arduino board. These pins are used for communication with your computer, including uploads. Connecting anything to these pins can interfere with uploads.
Make sure you have the correct board selected from the Tools > Board menu.
Make sure you have selected the port of your Arduino board from the Tools > Port menu.
Sometimes the port will be labeled with the board name in the menu. Other times it will not. If you don’t know which port is your Arduino board, you can find it like this:
- Unplug your Arduino board from the computer.
- Tools > Port
- Note the ports, if any, listed in the menu.
- Close the Tools menu. The ports list is only updated when the Tools menu is re-opened, so this step is essential.
- Plug your Arduino board into the computer.
- Tools > Port - The new port listed in the menu is your Arduino board.
