avrdude: target doesn't answer. What? This used to work...
Trying to burn bootloader into atmega328, but getting this error:
Arduino: 1.6.11 (Linux), Board: "ATmega328, Yes, 328 / 328A, 2.7v, Disabled (default), 8 MHz internal"
/home/paul/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino9/bin/avrdude -C/home/paul/.arduino15/packages/MiniCore/hardware/avr/2.0.1/avrdude.conf -v -patmega328 -cusbasp -Pusb -e -Ulock:w:0x3f:m -Uefuse:w:0xfd:m -Uhfuse:w:0xd6:m -Ulfuse:w:0xe2:m
avrdude: Version 6.3, compiled on Jan 17 2017 at 11:00:16
         Copyright (c) 2007-2014 Joerg Wunsch
         System wide configuration file is "/home/paul/.arduino15/packages/MiniCore/hardware/avr/2.0.1/avrdude.conf"
         User configuration file is "/home/paul/.avrduderc"
         User configuration file does not exist or is not a regular file, skipping
         Using Port                    : usb
         Using Programmer              : usbasp
         AVR Part                      : ATmega328
         Chip Erase delay              : 9000 us
         PAGEL                         : PD7
         BS2                           : PC2
         RESET disposition             : dedicated
         RETRY pulse                   : SCK
         serial program mode           : yes
         parallel program mode         : yes
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
                                  Block Poll               Page                       Polled
           Memory Type Mode Delay Size  Indx Paged  Size   Size #Pages MinW  MaxW   ReadBack
           eeprom        65    20     4    0 no       1024    4      0  3600  3600 0xff 0xff
           flash         65     6   128    0 yes     32768  128    256  4500  4500 0xff 0xff
           lfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           hfuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           efuse          0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           lock           0     0     0    0 no          1    0      0  4500  4500 0x00 0x00
           calibration    0     0     0    0 no          1    0      0     0     0 0x00 0x00
           signature      0     0     0    0 no          3    0      0     0     0 0x00 0x00
         Programmer Type : usbasp
         Description     : USBasp, http://www.fischl.de/usbasp/
avrdude: auto set sck period (because given equals null)
avrdude: warning: cannot set sck period. please check for usbasp firmware update.
avrdude: error: program enable: target doesn't answer. 1
avrdude: initialization failed, rc=-1
         Double check connections and try again, or use -F to override
         this check.
avrdude done.  Thank you.
Error while burning bootloader.
I understand this is often a wiring error, but I am using a board I made a couple of years ago for prototyping and burning bootloaders. I have used it several times to burn bootloaders and to upload sketches via ISP. So I know the wiring is correct. But it's been months since I last used it, and I have probably upgraded the IDE (currently 1.6.11) and various board packages since then.
I have tried using another atmega328. Same error. I know that atmega is OK because when I plug it back into the circuit I borrowed it from, it continues to run its old sketch perfectly.
I know the USBasp is OK, because I tested it by setting fuses and uploading the blink sketch to an attiny84. Works perfectly.
I tried building an ISP programming circuit on breadboard. Same error.
Here are the IDE settings I'm using:
Update: upgraded the MiniCore from 2.0.1 to 2.0.2. No change.
Any chance the chip you are using has the fuse bits set for external crystal?
Thanks for responding. Yes, it will have those fuse bits set. I was wondering if that could be the problem. So once a bootloader is burned that sets the fuses for external clock, you have to connect up a crystal to be able to set the clock back to internal?
Yes.
OK, thanks for your assistance with this. Some progress: different error message
Arduino: 1.6.11 (Linux), Board: "ATmega328, Yes (UART0), 328 / 328A, 2.7v, LTO disabled, 16 MHz external"
/home/paul/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino9/bin/avrdude -C/home/paul/.arduino15/packages/MiniCore/hardware/avr/2.0.2/avrdude.conf -v -patmega328 -cusbasp -Pusb -e -Ulock:w:0x3f:m -Uefuse:w:0b11111101:m -Uhfuse:w:0xd6:m -Ulfuse:w:0b11110111:m
         System wide configuration file is "/home/paul/.arduino15/packages/MiniCore/hardware/avr/2.0.2/avrdude.conf"
         Using Port                    : usb
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x000202
avrdude: Expected signature for ATmega328 is 1E 95 14
         Double check chip, or use -F to override this check.
The chip is atmega328-pu (not atmega328p-pu)
Check this from Gammon.
With the crystal there, the processor will tick over, and you can then program it. You might reconfigure it to no longer need the crystal.
Alternatively, if you have a spare board lying around, upload this sketch to it:
// For Atmega328
void setup ()
  // set up 8 MHz timer on pin 9
  pinMode (9, OUTPUT);
  // set up Timer 1
  TCCR1A = _BV (COM1A0);  // toggle OC1A on Compare Match
  TCCR1B = _BV(WGM12) | _BV(CS10);   // CTC, no prescaling
  OCR1A =  0;       // output every cycle
void loop () {}
That will output an 8 MHz clock to pin 9, so you could connect pin 9 (and Gnd) from the board running the "clock" sketch to the board requiring a clock signal. Plug the clock line into the XTAL1 pin.
Check your wiring for the crystal.
Second attempt, a different error:
         Using Port                    : usb
         PAGEL                         : PD7
         BS2                           : PC2
         RETRY pulse                   : SCK
         Timeout                       : 200
         StabDelay                     : 100
         CmdexeDelay                   : 25
         SyncLoops                     : 32
         ByteDelay                     : 0
         PollIndex                     : 3
         PollValue                     : 0x53
         Memory Detail                 :
avrdude: Device signature = 0x1e9514 (probably m328)
avrdude: erasing chip
avrdude: reading input file "0x3f"
avrdude: writing lock (1 bytes):
Writing | ################################################## | 100% 0.00s
avrdude: 1 bytes of lock written
avrdude: verifying lock memory against 0x3f:
avrdude: load data lock data from input file 0x3f:
avrdude: input file 0x3f contains 1 bytes
avrdude: reading on-chip lock data:
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0000
         0x3e != 0x3f
avrdude: verification error; content mismatch
Success! Bootloader burned.
Problem was, I had the USBasp set to output 3.3V. At 16MHz, the atmega328 needs 5V.
Good news. :slight_smile:
Yes. Unfortunately, still not out of the woods...
Switching to serial programming and attempting to upload the blink sketch:
WARNING: Category '' in library UIPEthernet is not valid. Setting to 'Uncategorized'
Sketch uses 1,078 bytes (3%) of program storage space. Maximum is 32,256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2,039 bytes for local variables. Maximum is 2,048 bytes.
/home/paul/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino9/bin/avrdude -C/home/paul/.arduino15/packages/MiniCore/hardware/avr/2.0.2/avrdude.conf -v -patmega328 -carduino -P/dev/ttyUSB1 -b115200 -D -Uflash:w:/tmp/buildbe7f94c1fb4df44bfe085b21fc070d63.tmp/Blink.ino.hex:i
         Using Port                    : /dev/ttyUSB1
         Using Programmer              : arduino
         Overriding Baud Rate          : 115200
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x00
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x00
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Invalid library found in /home/paul/sketchbook/libraries/ESP-1ch-Gateway-v2.0-master: /home/paul/sketchbook/libraries/ESP-1ch-Gateway-v2.0-master
Invalid library found in /home/paul/sketchbook/libraries/Adafruit_Trellis-master: /home/paul/sketchbook/libraries/Adafruit_Trellis-master
Invalid library found in /home/paul/sketchbook/libraries/arduino-api-master: /home/paul/sketchbook/libraries/arduino-api-master
Invalid version found: 1.04
Invalid library found in /home/paul/sketchbook/libraries/arduino-onewire-slave-master: /home/paul/sketchbook/libraries/arduino-onewire-slave-master
option enabled in File -> Preferences.
I thought you were using 8 MHz internal crystal, but you have selected 16 MHz external.
Sorry, my fault for confusing you by not explaining what I'm doing.
I'm still using the circuit with the 16MHz crystal, but now attempting up upload sketch via serial. I only have one 16MHz crystal, and that's soldered up on a stripboard circuit. But now, thanks to your advice, I think I can use that circuit to set fuses for 8MHz internal and burn bootloader on another atmega328, and use that in a different circuit. I had the foresight to put a socket for the atmega on the stripboard, so I can swap chips.
Anyway, I'm now trying to get a sketch uploaded over serial using a USB-serial adaptor. And I have made it work, but with difficulty.
Normally, I just connect the DTR pin on the USB-serial adaptor to the reset pin on the atmega and that works every time. (I also have 10K pull-up on the reset piin).
But for some reason, its not working. So I disconnected the atmega reset pin from DTR and connected it via a pushbutton to ground. By randomly clicking the pushbutton during the upload, I can get it to upload the sketch. But a lot of random clicking is envolved. It shouldn't be like this. On other circuits, using the DTR on my USB-serial adaptor works perfectly, no reset button required.
OK, fixed the reset problem by putting a 0.1uF cap between the atmega reset pin and the DTR pin on the USB-serial adaptor. The DTR line was pulling reset low for the entire upload process. The cap, in conjunction with the 10K pull-up, turns that constant low into a low pulse, which resets the atmega and allows sketch upload.
What I don't understand is how I got away with not having that cap in my other circuits...
I have been caught by that a couple of times. Using the Isp programmer you don't need the .1uF Cap, but then you need it for the USB-serial adapter. I have several minimum system programmers that have a .1uF capacitor tied to Gnd on the Reset lead and I have had to remove it to make the DTR pulse work.
kprims:
Today I learned that you must not have the 0.1uF cap in series with the reset line when using ISP programmer.
The 0.1uF I had needed to solder in the DTR-->Reset line, for serial programming, prevented me from later using the ISP programmer. To get ISP programming to work, I just needed to touch the Reset line from the programmer directly to the Reset pin on the atmega, bypassing the cap, when performing "Burn Bootloader".
@kprims, thanks again for your help.
You're welcome.
