avrdude: verification error
I'm getting the following error when uploading a sketch :
avrdude: verification error, first mismatch at byte 0x0000
0x00 != 0x0c
avrdude: verification error; content mismatch
but the thing is that the sketch is working.
for now I only uploaded the "blink" example.
why is he giving me this error although it works?
What board?
Can you do verbose uploads, and post the errors? I can't tell what it's failing to verify.
It's a freeduino.
I have a second Freeduino and that one gives me no errors.
what do you mean by "verbose"?
File:Preferences, there is a setting for Verbose outputs, shows what is going on behind the scenes.
Can copy/paste the results from the bottom window.
Ok, it'a alot so I'll only post the last part from avrdude :
avrdude: Version 6.0.1, compiled on Apr 15 2015 at 19:59:58
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM7
Using Programmer : arduino
Overriding Baud Rate : 19200
AVR Part : ATmega168
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 512 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 16384 128 128 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino
Description : Arduino
Hardware Version: 2
Firmware Version: 1.16
Vtarget : 0.0 V
Varef : 0.0 V
Oscillator : Off
SCK period : 0.1 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e9406
avrdude: reading input file "C:\Users\STEVEN~1.VET\AppData\Local\Temp\build2915415345263581304.tmp/Blink.cpp.hex"
avrdude: writing flash (1030 bytes):
Writing | ################################################## | 100% 0.86s
avrdude: 1030 bytes of flash written
avrdude: verifying flash memory against C:\Users\STEVEN~1.VET\AppData\Local\Temp\build2915415345263581304.tmp/Blink.cpp.hex:
avrdude: load data flash data from input file C:\Users\STEVEN~1.VET\AppData\Local\Temp\build2915415345263581304.tmp/Blink.cpp.hex:
avrdude: input file C:\Users\STEVEN~1.VET\AppData\Local\Temp\build2915415345263581304.tmp/Blink.cpp.hex contains 1030 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.86s
avrdude: verifying ...
0x00 != 0x0c
avrdude done. Thank you.
Someone that can help me?
