AVRDUDE Verification failed Content mismatch
Arduino: 1.8.3 (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 1274 bytes (3%) of program storage space. Maximum is 32256 bytes. Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes. C:\Program Files (x86)\Arduino\hardware\tools\avr/bin/avrdude -CC:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf -v -patmega328p -carduino -PCOM5 -b115200 -D -Uflash:w:C:\Users\HORACI~1\AppData\Local\Temp\arduino_build_423547/sketch_auto_delantero.ino.hex:i
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:00:53 Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/ Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "C:\Program Files (x86)\Arduino\hardware\tools\avr/etc/avrdude.conf"
Using Port : COM5 Using Programmer : arduino Overriding Baud Rate : 115200 AVR Part : ATmega328P Chip Erase delay : 9000 us PAGEL : PD7 BS2 : PC2 RESET disposition : dedicated RETRY pulse : SCK serial program mode : yes parallel program mode : yes Timeout : 200 StabDelay : 100 CmdexeDelay : 25 SyncLoops : 32 ByteDelay : 0 PollIndex : 3 PollValue : 0x53 Memory Detail :
Block Poll Page Polled Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 3600 3600 0xff 0xff flash 65 6 128 0 yes 32768 128 256 4500 4500 0xff 0xff lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00 calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00 signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : Arduino Description : Arduino Hardware Version: 3 Firmware Version: 4.4 Vtarget : 0.3 V Varef : 0.3 V Oscillator : 28.800 kHz SCK period : 3.3 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.00s
avrdude: Device signature = 0x1e950f (probably m328p) avrdude: reading input file "C:\Users\HORACI~1\AppData\Local\Temp\arduino_build_423547/sketch_auto_delantero.ino.hex" avrdude: writing flash (1274 bytes):
Writing | ################################################## | 100% 0.20s
avrdude: 1274 bytes of flash written avrdude: verifying flash memory against C:\Users\HORACI~1\AppData\Local\Temp\arduino_build_423547/sketch_auto_delantero.ino.hex: avrdude: load data flash data from input file C:\Users\HORACI~1\AppData\Local\Temp\arduino_build_423547/sketch_auto_delantero.ino.hex: avrdude: input file C:\Users\HORACI~1\AppData\Local\Temp\arduino_build_423547/sketch_auto_delantero.ino.hex contains 1274 bytes avrdude: reading on-chip flash data:
Reading | ########################################An error occurred while uploading the sketch
#### | 100% 0.15s
avrdude: verifying ... avrdude: verification error, first mismatch at byte 0x0019 0x14 != 0x94 avrdude: verification error; content mismatch
avrdude done. Thank you.
This report would have more information with "Show verbose output during compilation" option enabled in File -> Preferences.
Two points.
One:
hmerovich: This report would have more information with "Show verbose output during compilation" option enabled in File -> Preferences.
Two: Where did you buy it?
