arduino-cli upload mostly works but I've noticed it has issues with usbasp programmers when running on a raspberry pi 4b. It works on one usbasp board but not another. When I use:
arduino-cli upload --fqbn arduino:avr:pro:cpu=8MHzatmega328 --programmer usbasp Blink
I get:
avrdude: error: could not find USB device with vid=0x16c0 pid=0x5dc vendor='www.fischl.de' product='USBasp'
Failed programming: uploading error: exit status 1
The above values come from:
/home/pi/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf
It worked from the arduino ide so I used that from the commandline:
avrdude -C/home/pi/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf -v -patmega328p -carduino -P/dev/ttyUSB0 -b57600 -D -Uflash:w:/home/pi/dev/arduino/pro_mini_3v3/Blink/build/arduino.avr.pro/Blink.ino.hex:i
even though I'd selected USBasp as the Programmer in the ide it told avrdude to use "arduino" and the upload worked. It's not possible to replicate this with arduino-cli upload as it can't pass parameters to avrdude.
arduino-cli upload uses the same avrdude version and config file as the ide but with parameters that don't work:
/home/pi/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/bin/avrdude -C/home/pi/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino17/etc/avrdude.conf -v -V -patmega328p -cusbasp -Pusb "-Uflash:w:/tmp/arduino/sketches/1FA7F8DDA582FB74825745E708392493/Blink.ino.hex:i"
but it won't recognise the programmer as I when I use:
--programmer arduino
it just says:
Programmer 'arduino' not found
It seems arduino-cli upload is blocking access to avrdude if it doesn't recognise the programmer, which exists in the avrdude config file:
programmer
id = "arduino";
desc = "Arduino";
type = "arduino";
connection_type = serial;
Is it better to use avrdude directly as arduino-cli doesn't seem to be in step with avrdude configurations, as well as not being able to refine the avrdude environment.
