I am trying to flash a bootloader with the avrisp mkii from olimex.
But I get errors, at first it was because I used the wrong driver. Okay, switched to libusb. Then it was the wrong firmware in the programmer. Updated that as per the instructions. Finally I was using the wrong cable. Used the six to ten pin adapter.
Finally, I thought, it would work. But it didnt.
It goes for a minute attempting to flash a bootloader, but then it makes the usb disconnect noise and starts saying things like
stk500v2_command(): failed miserably to execute command 0x11
or
stk500v2_disable(): failed to leave programming mode
As I've exhausted all of my options, I am unsure what to do. I hope I didn't waste my money on this programmer. My usbtinyisp works on the same boards, but it is unable to program a mega r3 like I need to. (I made a pcb with a atmega2560 on it and I'm testing bootloader burning with a normal mega, but now I'm even just trying to get the darn thing to work on an uno.)
just did it again trying to program an arduino uno. usbtinyisp from adafruit works. avr-isp-mkii does not.
avrdude: stk500v2_recv_mk2: error in USB receive
avrdude: stk500v2_getsync(): timeout communicating with programmer
avrdude: stk500v2_command(): failed miserably to execute command 0x10
avrdude: stk500v2_command(): failed miserably to execute command 0x03
avrdude: stk500v2_getparm(): failed to get parameter 0xa1
avrdude: stk500v2_program_enable(): cannot get connection status
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: stk500v2_command(): failed miserably to execute command 0x11
avrdude: stk500v2_disable(): failed to leave programming mode
Error while burning bootloader.
Just figured out that my old usbtinyisp actually can program the mega. Just it won't verify properly, but it does work. I think.
YEP. I put flash example on it, it pulsated at 1 sec. Flashed a bootloader with usbtinyisp, it started up flashing faster. then I was able to successfully flash the example back on and slow it down again. So.. something is happening!
I would really like to get the mkii working though. I spent money on that thing and I want to use it, darn it.
I recommend going into the IDE preferences and setting show verbose output during upload. Then burn the bootloader with your programmer. The IDE will show you the avrdude commands it is attempting. You will notice the first command works, and the second command doesn't. Go ahead and copy and paste the second avrdude command to the command line and run it. The only reason the second command didn't work is because not enough time passes between the two avrdude commands. For those few occasions where you need to burn a bootloader, just do that. As Bill mentioned in that other thread, the fix may eventually make its way into the IDE. A recent thread with more detail: Solved:Bootloader from Arudino IDE with AVRISPmkII fails - Installation & Troubleshooting - Arduino Forum
itman496:
The first bandaid fix didn't seem to do it, in the thread.
I haven't tried the second one yet.
That one is just a variation of dmjlambert's but worth a try anyways, there may be multiple copies of platform.txt and which one needs to be modified for the first workaround depends on which board you have selected. The second doesn't have that issue. Make sure undo the changes made for the first one before trying the second.
itman496:
Strange that we can't just.. add a second or two pause.
