I've got a problem using this programmer ( https://www.diamex.de/dxshop/Diamex-ALL-AVR-ISP-Programmer ) with a Atmega168 connected via ISP (10Pin-Header) and Arduino using Debian.
I think it's a GUI-Problem, because:
avrdude -c avrispmkII -p m168 -P usb -e -v
will result in:
avrdude: Version 6.3
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/etc/avrdude.conf"
User configuration file is "/home/xgaduch/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : usb
Using Programmer : avrispmkII
avrdude: usbdev_open(): Found AVRISP mkII, serno: 0000000000000
AVR Part : ATmega168
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PC2
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 512 4 0 3600 3600 0xff 0xff
flash 65 6 128 0 yes 16384 128 128 4500 4500 0xff 0xff
lfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
efuse 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
lock 0 0 0 0 no 1 0 0 4500 4500 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : STK500V2
Description : Atmel AVR ISP mkII
Programmer Model: AVRISP mkII
Hardware Version: 0
Firmware Version Master : 1.32
Vtarget : 5.0 V
SCK period : 8.00 us
avrdude: AVR device initialized and ready to accept instructions
Reading | ################################################## | 100% 0.01s
avrdude: Device signature = 0x1e9406 (probably m168)
avrdude: safemode: hfuse reads as DD
avrdude: safemode: efuse reads as F9
avrdude: erasing chip
avrdude: safemode: Fuses OK (E:F9, H:DD, L:FF)
avrdude done. Thank you.
I added this Board-Package to arduino:
https://raw.githubusercontent.com/carlosefr/atmega/master/package_carlosefr_atmega_index.json
I added My Progger to "arduino-1.8.7/hardware/arduino/avr/programmers.txt" like this:
diamexallavr.name=Diamex All-AVR
diamexallavr.communication=usb
diamexallavr.protocol=stk500v2
diamexallavr.program.protocol=stk500v2
diamexallavr.program.tool=avrdude
diamexallavr.program.extra_params=-Pusb
~/.arduino15/packages/atmega/hardware/avr/1.3.1/boards.txt
reads like:
menu.cpu=Processor
menu.clock=Clock
# ATmega168/168p
atmega168.name=ATmega168/168p
#atmega168.bootloader.tool=arduino:avrdude
atmega168.bootloader.tool=avrdude
atmega168.bootloader.unlock_bits=0x3f
atmega168.bootloader.lock_bits=0x0f
#atmega168.upload.tool=arduino:avrdude
atmega168.upload.tool=avrdude
atmega168.upload.maximum_size=16384
atmega168.upload.maximum_data_size=1024
atmega168.upload.speed=19200
atmega168.upload.serial.port=usb
atmega168.build.variant=arduino:standard
atmega168.build.core=arduino:arduino
atmega168.build.board=atmega168
atmega168.menu.clock.external15=External 15 MHz
atmega168.menu.clock.external15.bootloader.low_fuses=0xff
atmega168.menu.clock.external15.bootloader.high_fuses=0xdd
atmega168.menu.clock.external15.bootloader.extended_fuses=0xf9
atmega168.menu.clock.external15.build.f_cpu=15000000L
~/.arduino15/packages/atmega/hardware/avr/1.3.1/plattform.txt
reads like:
name=ATmega Microcontrollers
tools.avrdude.path={runtime.tools.avrdude.path}
tools.avrdude.erase.params.verbose=-v -v -v -v
tools.avrdude.erase.params.quiet=-q -q
tools.avrdude.erase.pattern="{cmd.path}" "-C{config.path}" {erase.verbose} -p{build.mcu} -c{protocol} {program.extra_params} -e -Uefuse:w:{bootloader.extended_fuses}:m -Uhfuse:w:{bootloader.high_fuses}:m -Ulfuse:w:{bootloader.low_fuses}:m
tools.avrdude.bootloader.params.verbose=-v -v -v -v
tools.avrdude.bootloader.params.quiet=-q -q
tools.avrdude.bootloader.pattern="{cmd.path}" "-C{config.path}" {bootloader.verbose} -p{build.mcu} -c{protocol} {program.extra_params}
tools.avrdude-noefuse.path={runtime.tools.avrdude.path}
tools.avrdude-noefuse.cmd.path={runtime.ide.path}/hardware/tools/avr/bin/avrdude
tools.avrdude-noefuse.config.path={runtime.ide.path}/hardware/tools/avr/etc/avrdude.conf
tools.avrdude-noefuse.erase.params.verbose=-v -v -v -v
tools.avrdude-noefuse.erase.params.quiet=-q -q
tools.avrdude-noefuse.erase.pattern="{cmd.path}" "-C{config.path}" {erase.verbose} -p{build.mcu} -c{protocol} {program.extra_params} -e -Uhfuse:w:{bootloader.high_fuses}:m -Ulfuse:w:{bootloader.low_fuses}:m
tools.avrdude-noefuse.bootloader.params.verbose=-v -v -v -v
tools.avrdude-noefuse.bootloader.params.quiet=-q -q
tools.avrdude-noefuse.bootloader.pattern="{cmd.path}" "-C{config.path}" {bootloader.verbose} -p{build.mcu} -c{protocol} {program.extra_params}
Sadly, Arduino won't upload anything because I did not (and weren't able to) choose a port for Uploading, since the Programmer is using usb as Protocol&Port (See Attachment Unbenannt.PNG):
Arduino: 1.8.7 (Linux), Board: "ATmega168/168p, External 15 MHz, ATmega168"
Der Sketch verwendet 8658 Bytes (52%) des Programmspeicherplatzes. Das Maximum sind 16384 Bytes.
Globale Variablen verwenden 713 Bytes (69%) des dynamischen Speichers, 311 Bytes für lokale Variablen verbleiben. Das Maximum sind 1024 Bytes.
Bitte wählen Sie vor dem Hochladen einen Port aus
Dieser Bericht wäre detaillierter, wenn die Option
"Ausführliche Ausgabe während der Kompilierung"
in Datei -> Voreinstellungen aktiviert wäre.
I guess, this will be a common issue, but didn't find anything helpfully. Adding the Udev-Rules to create a symlink won't show the Progger under /dev/
What to try next?
