Hi to all,
Can some one has success using the perfect editor AVRProjectIDE with the new Arduino 1.0
I have go to Tools --> Editor Settings --> and i select for the Core files: C:\arduino-1.0\hardware\arduino\cores\arduino
and for the libraries: C:\arduino-1.0\libraries
but when i compile i got errors the first of that is:
file line Where Message
wiring_digital.c 138 'digitalWrite' undefined reference to 'port_to_output_PGM'
Can some one please help me ?
Thank you in advance.
Did you include Arduino.h like the Arduinbo IDE does?
Hello Dear johnwasser,
Thank you very much for the reply and sorry for the delay on my reply.
I was try to add on top the #include "Arduino.h"
But no working
Did you include the appropriate pins_arduino.h like from hardware/arduino/variants/standard/pins_arduino.h?
Thank you very much for the reply.
I was try again today with you're tip, i copy the file pins_arduino.h in Core folder and i was try to compile the bellow code:
#include <Arduino.h>
//#include <pins_arduino.h>
int power;
float sensor=0;
float input=0;//voltage read on pin 2
float celsius=0;
float fahrenheit=0;
void setup(){
pinMode(3,INPUT);
void loop(){
power= digitalRead(3);
if (power==HIGH){
sensor = analogRead(A0);
input = (sensor*5000)/1024; // convert raw sensor value to millivolts
celsius = input/10; // convert millivolts to Celsius
fahrenheit = ((celsius * 1.8)+32); // convert celsius to fahrenheit
Serial.println(" sensor read");
Serial.println(sensor);
Serial.println(" --------------------------");
Serial.print("Temperature: ");
Serial.print(celsius,2);
Serial.println(" degrees C");
Serial.print(fahrenheit,2);
Serial.println(" degrees F");
Serial.println("_ _ _ _ _ _ _ _ _ _ _ _ _ _ ");
delay (2000); // wait a second, otherwise the serial monitor box will be too difficult to read
Without luck
The only good it was the errors it is only 3 from many it was before
Look the error if you can please, maybe you can understend more than me. ( I am sure for this
Looks like you have to add:
int main()
setup();
while (1)
loop();
Not sure why it's complaining about pulseIn(). Looks like it might be declared twice.
