AWS IOT activate a Relay via mqtt and ArduinoYun
I created a project with an ArduinoYUN and Temp sensor. Every 5 seconds the sensor send info to AWS IOT platform.
Now I wold like to Publish a topic to Another YUN and this activate a relay. Does anybody how to do it?
This is the scketck for the sensor Arduino:
#include <aws_iot_mqtt.h>
#include <aws_iot_version.h>
#include "aws_iot_config.h"
aws_iot_mqtt_client myClient; // init iot_mqtt_client
char msg[32]; // read-write buffer
int cnt = 0; // loop counts
int rc = -100; // return value placeholder
bool success_connect = false; // whether it is connected
#include <ArduinoJson.h>
char data[80];
StaticJsonBuffer<200> jsonBuffer;
#include <Process.h>
Process date;                 // process used to get the date
#include "DHT.h" //cargamos la librería DHT
#define DHTPIN 2 //Seleccionamos el pin en el que se conectará el sensor
#define DHTTYPE DHT22 //Se selecciona el DHT22(hay otros DHT)
DHT dht(DHTPIN, DHTTYPE); //Se inicia una variable que será usada por Arduino para comunicarse con el sensor
const int moisturePin = A1;    // Grove Moisture sensor connected to A1 on the Grove Shield
const int ledPin = 2;
int moisturValue = 0;  // variable to store the Moisture Sensor
const int lightPin = A2; //variable to store the Light Sensor
// Basic callback function that prints out the message
void msg_callback(char* src, int len) {
  Serial.println("CALLBACK:");
  int i;
  for(i = 0; i < len; i++) {
    Serial.print(src[i]);
  Serial.println("");
  // Start Serial for print-out and wait until it's ready
  while(!Serial);
  dht.begin(); //Se inicia el sensor
  Bridge.begin();        // initialize Bridge
  char curr_version[80];
  snprintf_P(curr_version, 80, PSTR("AWS IoT SDK Version(dev) %d.%d.%d-%s\n"), VERSION_MAJOR, VERSION_MINOR, VERSION_PATCH, VERSION_TAG);
  Serial.println(curr_version);
  // Set up the client
  if((rc = myClient.setup(AWS_IOT_CLIENT_ID)) == 0) {
    // Load user configuration
    if((rc = myClient.config(AWS_IOT_MQTT_HOST, AWS_IOT_MQTT_PORT, AWS_IOT_ROOT_CA_PATH, AWS_IOT_PRIVATE_KEY_PATH, AWS_IOT_CERTIFICATE_PATH)) == 0) {
      // Use default connect: 60 sec for keepalive
      if((rc = myClient.connect()) == 0) {
        success_connect = true;
        // Subscribe to "topic1"
        if((rc = myClient.subscribe("topic1", 1, msg_callback)) != 0) {
          Serial.println("Subscribe failed!");
          Serial.println(rc);
      else {
        Serial.println(F("Connect failed!"));
        Serial.println(rc);
    else {
      Serial.println(F("Config failed!"));
      Serial.println(rc);
  else {
    Serial.println(F("Setup failed!"));
    Serial.println(rc);
  // Delay to make sure SUBACK is received, delay time could vary according to the server
  delay(2000);
  //Lectura Hora de Sistema
  date.begin("/bin/date");
  date.addParameter("+%d/%m/%Y %T");
  date.run();
  String timeString = date.readString();
  //Lecturas de Sensores
  float humity = dht.readHumidity(); //Se lee la humedad
  int temperature = dht.readTemperature(); //Se lee la temperatura
  moisturValue = analogRead(moisturePin);//Se lee la humedad del suelo
  int lightValue = analogRead(lightPin); //Se lee la luz solar
  //Se imprimen las variables
     //sprintf(msg,"\"Temperature\": %d", temperature);
    Serial.print("moisture = " ); Serial.println(moisturValue); //Check the Value for with Dry sand and then with Wet Sand
    Serial.print("light value = ");  Serial.println(lightValue);
    Serial.print("Temperatura= ");Serial.println(temperature);
    Serial.print("Humedad= ");Serial.println(humity);
   //Creating the JSON payload
 String temp = "\"Temperature\": " + String(temperature) ;
 String humi = ", \"Humity\": " + String(humity) ;
 String light = ", \"lightval\":" + String(lightValue) ;
 String soilMoist = ", \"moistval\":" + String(moisturValue) ;
 // Add both value together to send as one string.
 String value = temp + humi + light +soilMoist;
 Serial.println(value);
 String payload = "{" + value + "}";
 payload.toCharArray(data, (payload.length() + 1));
  //Json File
  //Serial.print("\{");Serial.print("\"Id\":\"001\"\,");Serial.print("\"Date\":\"");Serial.print(timeString);Serial.print("\"\,"); Serial.print("\"Temperature\":\"");Serial.print(t);Serial.print("\"");Serial.println("\}");
  delay(10000); //Se espera 10 segundos para seguir leyendo //datos
 //Publish data to AWS IoT using  topic/plantdata,which in turn will fire the AWS IoT rule to write sensor data to Dynamo DB
 if(success_connect) {
    // Generate a new message in each loop and publish to "topic/plantdata"
    if((rc = myClient.publish("topic1", data, strlen(data), 1, false)) != 0) {
      Serial.println("Publish failed!");
      Serial.println(rc);
    // Get a chance to run a callback
    if((rc = myClient.yield()) != 0) {
      Serial.println("Yield failed!");
      Serial.println(rc);
    // Done with the current loop
    sprintf(msg, "publish %d done", cnt++);
    Serial.println(msg);
    delay(10000);
 // }//end if checking for time interval to post
  delay(5000);
Thank you very much
Eduard
