Buenas,
Se que se ha hablado muchismo a cerca de este tema y antes de escribir aquí he mirado muchisimo…
Tengo el Uno y el problema que tengo es que he adquirido GSM/GPRS shield (este específicamente: http://img1.mlstatic.com/shield-gsm-gprs-sim-envie-sms-com-seu-arduino_MLB-O-4218862132_042013.jpg). y no consigo mandar un sms con el ejemplo.
El código que envió es el siguiente:
SMS sender
This sketch, for the Arduino GSM shield,sends an SMS message
you enter in the serial monitor. Connect your Arduino with the
GSM shield and SIM card, open the serial monitor, and wait for
the “READY” message to appear in the monitor. Next, type a
message to send and press “return”. Make sure the serial
monitor is set to send a newline when you press return.
Circuit:
- GSM shield
- SIM card that can send SMS
created 25 Feb 2012
by Tom Igoe
This example is in the public domain.
// Include the GSM library
#include <GSM.h>
#define PINNUMBER “6969” //Número PIN
// initialize the library instance
GSM gsmAccess;
GSM_SMS sms;
// initialize serial communications and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
Serial.println(“666666666”); //El numero que manda el sms
// connection state
boolean notConnected = true;
// Start GSM shield
// If your SIM has PIN, pass it as a parameter of begin() in quotes
while(notConnected)
if(gsmAccess.begin(PINNUMBER)==GSM_READY)
notConnected = false;
Serial.println(“Not connected”);
Serial.println(“GSM initialized”);
Serial.print(“666000000”); // Número receptor del sms
char remoteNum[20]; // telephone number to send sms
readSerial(remoteNum);
Serial.println(remoteNum);
// sms text
Serial.print(“Mensaje desde arduino”); //Mensaje a enviar
char txtMsg[200];
readSerial(txtMsg);
Serial.println(“SENDING”);
Serial.println(“Message:”);
Serial.println(txtMsg);
// send the message
sms.beginSMS(remoteNum);
sms.print(txtMsg);
sms.endSMS();
Serial.println("\nCOMPLETE!\n");
Read input serial
int readSerial(char result)
int i = 0;
while(1)
while (Serial.available() > 0)
char inChar = Serial.read();
if (inChar == ‘\n’)
result = ‘\0’;
- Serial.flush();*
- return 0;*
- if(inChar!=’\r’)*
_ result = inChar;_
* i++;*
¿Estoy metiendo algo mal? ¿Tengo que configurar algo en cuanto a telecomunicaciones? ¿Es fallo de hardware?
Muchas gracias de antemano
