Hola soy nuevo con arduino y me intereso mucho un proyecto pero no se por que no lo puedo cargar a la placa ojala alguien me pueda ayudar gracias.
esta es la pagina
http://www.beavisaudio.com/Projects/digital/ArduinoPunkConsole/index.htm
y este es el programa
Arduino Punk Console
A simple programmable 8 step tone sequencer
by dano/beavisaudio.com
Revs15 Sept djh initial version
// Map all the input and output pins
#define AnalogInFrequency 1
#define AnalogInTempo 2
#define AnalogInDuration 0
#define DigitalOutSignal 11
#define DigitalInSwitch0 2
#define DigitalInSwitch1 3
#define DigitalInSwitch2 4
#define DigitalInSwitch3 5
#define DigitalInSwitch4 6
#define DigitalInSwitch5 7
#define DigitalInSwitch6 8
#define DigitalInSwitch7 9
#define DigitalInStartStop 10
#define DigitalOutLED 12
// Set up the array for each step
int steps[] = {100,120,140,160,180,200,220,240};
// misc housekeeping
int duration = 50;
int pitchval = 1;
int fPlayMode = true;
int lastPushedStep = -1;
// Initialize the tempo
int tempo = 100;
// setup pin modes (Digital pins are input by default, but
// I like to set 'em explicitly just so the code is clear.
pinMode (DigitalInSwitch0, INPUT);
pinMode (DigitalInSwitch1, INPUT);
pinMode (DigitalInSwitch2, INPUT);
pinMode (DigitalInSwitch3, INPUT);
pinMode (DigitalInSwitch4, INPUT);
pinMode (DigitalInSwitch5, INPUT);
pinMode (DigitalInSwitch6, INPUT);
pinMode (DigitalInSwitch7, INPUT);
pinMode (DigitalInStartStop, INPUT);
pinMode (DigitalOutSignal, OUTPUT);
pinMode (DigitalOutLED, OUTPUT);
// setup comms for the LCD display
Serial.begin(9600);StartupMessage();
void StartupMessage()
clearLCD();
Serial.print ("BEAVIS: Arduino");
delay(300);
Serial.print (254, BYTE);
Serial.print (192, BYTE);
Serial.print ("Punk Console!");
delay (2000);
clearLCD();
Serial.print ("Beavis: APC");
}void clearLCD()
Serial.print(254, BYTE);
Serial.print(1, BYTE);
}void loop()
// Main sequence loop
for (int i=0; i<8; i++)
// Are we playing or stopping?
fPlayMode = digitalRead (DigitalInStartStop);
digitalWrite (DigitalOutLED, HIGH);
// Check the Hardware
readSwitches();
readPots();// update the display
updateDisplay();// Make the noise
if (fPlayMode)
freqout (steps*, duration);*
- digitalWrite (DigitalOutLED, LOW);*
- // Pause between steps*
- delay (tempo); *
void updateDisplay()
{- Serial.print (254, BYTE);*
- Serial.print (192, BYTE);*
- Serial.print ("T:");*
- Serial.print (tempo);*
- Serial.print (" d:");*
- Serial.print (duration);*
if (lastPushedStep != -1)
_ Serial.print ("*");_- Serial.print (lastPushedStep);*
// Read the current values of the pots, called from the loop.
void readPots ()
_ tempo = (analogRead (AnalogInTempo) * 1.9);_- duration = (analogRead (AnalogInDuration)); *
// Read the current values of the switches and
// if pressed, replace the switch's slot frequency
// by reading the frequency pot.
void readSwitches()
{- // reset last pushed button number*
- lastPushedStep = -1;*
- // check switch 0, if pressed, get the current freq into step 0, etc. etc.*
- if (digitalRead (DigitalInSwitch0) == HIGH)*
- steps[0] = analogRead(AnalogInFrequency);*
- lastPushedStep = 1;*
- else if (digitalRead (DigitalInSwitch1) == HIGH)*
- steps[1] = analogRead(AnalogInFrequency);*
- lastPushedStep = 2;*
- else if (digitalRead (DigitalInSwitch2) == HIGH)*
- steps[2] = analogRead(AnalogInFrequency);*
- lastPushedStep = 3;*
- else if (digitalRead (DigitalInSwitch3) == HIGH)*
- steps[3] = analogRead(AnalogInFrequency);*
- lastPushedStep = 4;*
- else if (digitalRead (DigitalInSwitch4) == HIGH)*
- steps[4] = analogRead(AnalogInFrequency);*
- lastPushedStep = 5;*
- else if (digitalRead (DigitalInSwitch5) == HIGH)*
- steps[5] = analogRead(AnalogInFrequency);*
- lastPushedStep = 6;*
- else if (digitalRead (DigitalInSwitch6) == HIGH)*
- steps[6] = analogRead(AnalogInFrequency);*
- lastPushedStep = 7;*
- else if (digitalRead (DigitalInSwitch7) == HIGH)*
- steps[7] = analogRead(AnalogInFrequency);*
- lastPushedStep = 8;*
//freqout code by Paul Badger
// freq - frequency value
// t - time duration of tone
void freqout(int freq, int t)
{- int hperiod; //calculate 1/2 period in us*
- long cycles, i;*
- // subtract 7 us to make up for digitalWrite overhead - determined empirically*
_ hperiod = (500000 / ((freq - 7) * pitchval)); _- // calculate cycles*
_ cycles = ((long)freq * (long)t) / 1000; // calculate cycles_- for (i=0; i<= cycles; i++)*
- { // play note for t ms *
- digitalWrite(DigitalOutSignal, HIGH); *
- delayMicroseconds(hperiod);*
- digitalWrite(DigitalOutSignal, LOW); *
- delayMicroseconds(hperiod - 1); // - 1 to make up for fractional microsecond in digitaWrite overhead*
[/quote]
