Saludos amigos, tengo el siguiente problema con el código que encontré, es tratado de compilarlo cambiando los archivos .h pero no logro solucionar el error "In file included from sketch_mar15a.cpp:1:
C:\Users\Equipo 1\Desktop\arduino-1.0\libraries\Password/Password.h:33:22: error: WProgram.h: No such file or directory
C:\Users\Equipo 1\Desktop\arduino-1.0\libraries\Password/Password.h:61: error: 'byte' does not name a type"
El codigo es el siguiente :
#include <Password.h>
#include <Keypad.h>
Password password = Password( "1234" );
const byte ROWS = 4; // Four rows
const byte COLS = 3; // Three columns
// Define the Keymap
char keys[ROWS][COLS] = {
{'1','2','3',},
{'4','5','6',},
{'7','8','9',},
{'*','0','#',}
// Connect keypad ROW0, ROW1, ROW2 and ROW3 to these Arduino pins.
byte rowPins[ROWS] = { 2, 3, 4, 5, };// Connect keypad COL0, COL1 and COL2 to these Arduino pins.
byte colPins[COLS] = { 6, 7, 8 };
// Create the Keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
#define ledPin 13
void setup(){
digitalWrite(ledPin, LOW); // sets the LED on
keypad.addEventListener(keypadEvent); //add an event listener for this keypad
keypad.setDebounceTime(250);
void loop(){
keypad.getKey();
//take care of some special events
void keypadEvent(KeypadEvent eKey){
switch (keypad.getState()){
case PRESSED:
Serial.print("Pressed: ");
Serial.println(eKey);
switch (eKey){
case '#': guessPassword(); break;
default:
password.append(eKey);
void guessPassword(){
Serial.print("Guessing password... ");
if (password.evaluate()){
digitalWrite(ledPin,HIGH); //activates garaged door relay
digitalWrite(ledPin,LOW); //turns off door relay after .5 sec
Serial.println("VALID PASSWORD "); //
password.reset(); //resets password after correct entry
}else{
Serial.println("INVALID PASSWORD ");
password.reset(); //resets password after INCORRECT entry
gracias por ayudarme, saludos !!
