Hola amigos, tengo este codigo montado en un Arduino UNO que prende y apaga las luces (con una placa de reles) segun la hora (con un reloj RTC ), que me funcionaba hasta ahora, desde que cambie la configuracion horaria solo prende la primera luz (nisiquiera volviendo a poner los horarios anteriores), si me pueden ayudar, Saludos
#include <Wire.h>
#include "RTClib.h"
RTC_DS1307 RTC;
unsigned int StartHr = 6;
unsigned int StartMin = 0;
unsigned int StartHr4 = 9;
unsigned int StartMin4 = 0;
unsigned int StartHr6 = 9;
unsigned int StartMin6 = 0;
unsigned int StartDayofWeek;
unsigned int CurrentDay;
unsigned int EndDay;
long Sleep = 1L;
long MultiMinute = 60000L;
boolean LightOn = false;
boolean LightOn4 = false;
boolean LightOn6 = false;
unsigned int EndHr = 23;
unsigned int EndMin = 59;
unsigned int EndHr4 = 21;
unsigned int EndMin4 = 0;
unsigned int EndHr6 = 21;
unsigned int EndMin6 = 0;
int ledPin = 13;
// Pins used to control latching relay
int RelayOn = 6;
int RelayOff = 6;
int RelayOn4 = 7;
int RelayOff4 = 7;
int RelayOn6 = 8;
int RelayOff6 = 8;
void setup () {
Serial.begin(57600);
Wire.begin();
RTC.begin();
pinMode(RelayOn, OUTPUT);
pinMode(RelayOff,OUTPUT);
pinMode(RelayOn4, OUTPUT);
pinMode(RelayOff4,OUTPUT);
pinMode(RelayOn6, OUTPUT);
pinMode(RelayOff6,OUTPUT);
RTC.adjust(DateTime(__DATE__, __TIME__));
if (! RTC.isrunning()) {
Serial.println("RTC is NOT running!");
// following line sets the RTC to the date & time this sketch was compiled
void loop () {
DateTime now = RTC.now();
Serial.print(now.year(), DEC);
Serial.print('/');
Serial.print(now.month(), DEC);
Serial.print('/');
Serial.print(now.day(), DEC);
Serial.print(' ');
Serial.print(now.hour(), DEC);
Serial.print(':');
Serial.print(now.minute(), DEC);
Serial.print(':');
Serial.print(now.second(), DEC);
// reley 1
if (LightOn == false)
if (((int)now.hour() >= StartHr && (int)now.minute() >= StartMin) &&
((int)now.hour() <= EndHr && (int)now.minute() < EndMin))
// turn on light
LightOn = true;
digitalWrite(RelayOn, HIGH);
Serial.print("Light On");
// only need a short time to trigger the latching relay
//then we can turn the port back off
//delay(1000);
//digitalWrite(RelayOn, LOW);
// Check curren time, turn off light when conditions are met
if ((int)now.hour() >= EndHr && (int)now.minute() >= EndMin)
LightOn = false;
// turn light off
digitalWrite(RelayOff, HIGH);
Serial.print("Light Off");
digitalWrite(RelayOff, LOW);
// Reley 4
if (LightOn4 == false)
if (((int)now.hour() >= StartHr4 && (int)now.minute() >= StartMin4) &&
((int)now.hour() <= EndHr4 && (int)now.minute() < EndMin4))
// turn on light 4
LightOn4 = true;
digitalWrite(RelayOn4, HIGH);
Serial.print("Light 4 On");
if ((int)now.hour() >= EndHr4 && (int)now.minute() >= EndMin4)
LightOn4 = false;
// turn light off
digitalWrite(RelayOff4, HIGH);
Serial.print("Light 4 Off");
digitalWrite(RelayOff4, LOW);
// Reley6
if (LightOn6 == false)
if (((int)now.hour() >= StartHr6 && (int)now.minute() >= StartMin6) &&
((int)now.hour() <= EndHr6 && (int)now.minute() < EndMin6))
// turn on light
LightOn6 = true;
digitalWrite(RelayOn6, HIGH);
//delay(1000);
if ((int)now.hour() >= EndHr6 && (int)now.minute() >= EndMin6)
LightOn6 = false;
// turn light off
digitalWrite(RelayOff6, HIGH);
digitalWrite(RelayOff6, LOW);
delay((Sleep*MultiMinute));
