ayuda! Encender un LED mientras se presiona un boton y al soltarlo se apaga
Hola c: les dejo mi código en C#:
using System.Linq;
using System.Windows.Forms;
using System.IO.Ports;
using encender_Led_arduino.Properties;
namespace encender_Led_arduino
    public partial class Form1 : Form
        public Form1()
            InitializeComponent();
            serialPort1.PortName = "COM30";
            serialPort1.BaudRate = 9600;
            serialPort1.Open();
        private void Form1_FormClosing(object sender, FormClosingEventArgs e)
            if (serialPort1.IsOpen) serialPort1.Close();
        private void ON_Click(object sender, EventArgs e)
            serialPort1.Write("1");
        private void OFF_Click(object sender, EventArgs e)
            serialPort1.Write("0");
y del arduino:
  pinMode(13, OUTPUT);
  if(Serial.available())
    int c = Serial.read();
    if (c == '1')
      digitalWrite(13,HIGH);
    else if (c == '0')
      digitalWrite(13,LOW);
Esto hace que al darle clic a un botón en la interfaz de C# encienda el led y al darle clic a otro se apague. Alguien podría ayudarme para hacer que al darle clic a un único botón se encienda el led pero al soltarle se apague??
gracias:)
El ejemplo Button.ino del IDE te puede servir.
Button
Turns on and off a light emitting diode(LED) connected to digital
pin 13, when pressing a pushbutton attached to pin 2.
The circuit:
  • LED attached from pin 13 to ground
  • pushbutton attached to pin 2 from +5V
  • 10K resistor attached to pin 2 from ground
  • Note: on most Arduinos there is already an LED on the board
    attached to pin 13.
created 2005
by DojoDave http://www.0j0.org
modified 30 Aug 2011
by Tom Igoe
This example code is in the public domain.
http://www.arduino.cc/en/Tutorial/Button
// constants won’t change. They’re used here to
// set pin numbers:
const int buttonPin = 2; // the number of the pushbutton pin
const int ledPin = 13; // the number of the LED pin
// variables will change:
int buttonState = 0; // variable for reading the pushbutton status
// initialize the LED pin as an output:
pinMode(ledPin, OUTPUT);
// initialize the pushbutton pin as an input:
pinMode(buttonPin, INPUT);
void loop(){
// read the state of the pushbutton value:
buttonState = digitalRead(buttonPin);
// check if the pushbutton is pressed.
// if it is, the buttonState is HIGH:
if (buttonState == HIGH) {
// turn LED on:
digitalWrite(ledPin, HIGH);
else {
// turn LED off:
digitalWrite(ledPin, LOW);
Hola,
Lo que necesitas es manejar en C# el evento de soltar la tecla, que supongo es KeyUP o Release o algo asi.
Saludos.
