Hola
de un ejemplo que encontre he añadido un nuevo swich el “yellow” que me hacia falta y no hay forma de que funcione siempre va a “on” lo que copiado exactamente, igual tambien en el NetIO
Alguna idea?
Simple Webserver sketch for NetIO Application
Tutorial on http://netio.davideickhoff.de
#include <SPI.h>
#include <Ethernet.h>
#define BUFFER 10
// CONFIGURATION
byte mac[] = { 0x54, 0x55, 0x58, 0x10, 0x00, 0x24 }; // MAC address 84.85.88.16.0.36
byte ip[] = { 192,168,1,50}; // ip-address, please change to fit your network
//byte gateway[] = { 192, 168, 1, 1 }; // Gateway
//byte subnet[] = { 255, 255, 255, 0 };
//byte dn[] = { 192, 168, 1, 1 };
// example has an RGB diode connected to three pins
int redLed = 47;
int greenLed = 48;
int blueLed = 49;
int yellowLed = 50;
int dipositple = 31;
int h=0;
EthernetServer server(3200);
String readString = String(100); // string for fetching data from address
int humitat = A8;
void setup(){
//Ethernet.begin(mac, ip,gateway, subnet,dn);
Ethernet.begin(mac, ip);
server.begin();
// configure LED pins
pinMode(redLed, OUTPUT);
pinMode(greenLed, OUTPUT);
pinMode(blueLed, OUTPUT);
pinMode(yellowLed,OUTPUT);
pinMode(dipositple, INPUT);
void loop(){
h = analogRead(humitat);
char comando[BUFFER];
if (client) {
// an http request ends with a blank line
boolean currentLineIsBlank = true;
while (client.connected()) {
if (client.available()) {
char c = client.read();
Serial.print(c);
if (readString.length() < 100) {
//store characters to string
readString = readString + c;
// if you've gotten to the end of the line (received a newline
// character) and the line is blank, the http request has ended,
// so you can send a reply
if (c == '\n' && currentLineIsBlank) {
// send a standard http response header
client.println("Content-Type: text/html");
client.println("Connection: close");
client.println();
// conditions for get parameters
if(readString.indexOf("red=") > -1) {
digitalWrite(redLed, (readString.indexOf("=1") > -1) ? HIGH : LOW);
else if(readString.indexOf("green=") > -1) {
digitalWrite(greenLed, (readString.indexOf("=1") > -1) ? HIGH : LOW);
else if(readString.indexOf("blue=") > -1) {
digitalWrite(blueLed, (readString.indexOf("=1") > -1) ? HIGH : LOW);
else if(readString.indexOf("yellow=") > -1) {
digitalWrite(yellowLed, (readString.indexOf("=1") > -1) ? HIGH : LOW);
//if (strstr(comando, "nivell"))
if(readString.indexOf("nivell")>-1) //paraula que envia netio
{client.println("NIVELL DIPOSIT");
if (digitalRead(dipositple) == HIGH) {
client.println("CORRECTE");
client.println("ALARMA"); //digitalWrite(blueLed,HIGH);
client.print ("h=");
client.println (h);
if (digitalRead(dipositple) == LOW) { digitalWrite(greenLed,HIGH);}
if(readString.indexOf("status=") > -1 ) {
// status requests
if (readString.indexOf("red") > -1)
client.print(digitalRead(redLed));
else if (readString.indexOf("green") > -1)
client.print(digitalRead(greenLed));
else if (readString.indexOf("blue") > -1)
client.print(digitalRead(blueLed));
else if (readString.indexOf("yellow") > -1)
client.print(digitalRead(yellowLed));
client.print("invalid parameter");
} else if(readString.indexOf("read=") > -1 ) {
//generic response according to incoming GET parameter
client.print(String(readString.substring(readString.indexOf("=")+1, readString.indexOf("_"))));
client.println(" CONEXIO OK");
//clear string for next read
readString="";
if (c == '\n') {
// you're starting a new line
else if (c != '\r') {
// you've gotten a character on the current line
currentLineIsBlank = false;
// give the web browser time to receive the data
delay(1);
// close the connection:
client.stop();
