Ayuda-Por favor-
Alguien me podría ayudar a resolver los siguientes errores que me aparecen. : :
Arduino:1.6.4 (Windows 7), Placa:“Arduino Uno”
Me aparecen los siguientes errores al correr el código ya que es para Arduino Due y yo estoy utilizando el Arduino UNO y no se que pueda cambiar para componer los errores:
Este es el código que estoy utilizando.
int in_ADC0, in_ADC1;  //variables for 2 ADCs values (ADC0, ADC1)
   int POT0, POT1, POT2, out_DAC0, out_DAC1; //variables for 3 pots (ADC8, ADC9, ADC10)
   int LED = 3;
   int FOOTSWITCH = 7;
   int TOGGLE = 2;
   int toggle_value = 0;
   int effect=0;
   int upper_threshold, lower_threshold;
   #define MAX_DELAY 40000
   uint16_t sDelayBuffer0[MAX_DELAY];
   unsigned int Delay_Depth, DelayCounter = 0;
   #define MAX_DELAY 500
   #define MIN_DELAY 200
unsigned int count_up=1;
int p;
   /* turn on the timer clock in the power management controller */
  pmc_set_writeprotect(false);
  pmc_enable_periph_clk(ID_TC4);
  /* we want wavesel 01 with RC */
  TC_Configure(/* clock */TC1,/* channel */1, TC_CMR_WAVE | TC_CMR_WAVSEL_UP_RC
  | TC_CMR_TCCLKS_TIMER_CLOCK2);
  TC_SetRC(TC1, 1, 238); // sets <> 44.1 Khz interrupt rate
  //TC_SetRC(TC1, 1, 109); // sets <>   96 Khz interrupt rate
  TC_Start(TC1, 1);
  // enable timer interrupts on the timer
  TC1->TC_CHANNEL[1].TC_IER=TC_IER_CPCS;
  TC1->TC_CHANNEL[1].TC_IDR=~TC_IER_CPCS;
  /* Enable the interrupt in the nested vector interrupt controller */
  /* TC4_IRQn where 4 is the timer number * timer channels (3) + the channel number
  (=(1*3)+1) for timer1 channel1 */
  NVIC_EnableIRQ(TC4_IRQn);
  //ADC Configuration
  ADC->ADC_MR |= 0x80;   // DAC in free running mode.
  ADC->ADC_CR=2;         // Starts ADC conversion.
  ADC->ADC_CHER=0x1CC0;    // Enable ADC channels 0 and 1.
  //DAC Configuration
  analogWrite(DAC0,0);  // Enables DAC0
  analogWrite(DAC1,0);  // Enables DAC0
  //configure pin2 as an input and enable the internal pull-up resistor
  pinMode(LED, OUTPUT);
  pinMode(TOGGLE, INPUT_PULLUP);
  attachInterrupt(TOGGLE, switch_handler, CHANGE);
  pinMode(FOOTSWITCH, INPUT);
  //Read the ADCs
  while((ADC->ADC_ISR & 0x1CC0)!=0x1CC0);  // wait for ADC 0, 1, 8, 9, 10 conversion complete.
  in_ADC0=ADC->ADC_CDR[7];             // read data from ADC0
  in_ADC1=ADC->ADC_CDR[6];             // read data from ADC1
  POT0=ADC->ADC_CDR[10];                   // read data from ADC8
  POT1=ADC->ADC_CDR[11];                   // read data from ADC9
  POT2=ADC->ADC_CDR[12];                   // read data from ADC10
void TC4_Handler()
   // We need to get the status to clear it and allow the interrupt to fire again
  TC_GetStatus(TC1, 1);
  if (effect==0) // EFFECT 0: Volume-Booster
  digitalWrite(LED, HIGH);
  //Adjust the volume with POT2
  out_DAC0=map(in_ADC0,0,4095,1,POT2);
  out_DAC1=map(in_ADC1,0,4095,1,POT2);
  //Write the DACs
  dacc_set_channel_selection(DACC_INTERFACE, 0);          //select DAC channel 0
  dacc_write_conversion_data(DACC_INTERFACE, out_DAC0);//write on DAC
  dacc_set_channel_selection(DACC_INTERFACE, 1);          //select DAC channel 1
  dacc_write_conversion_data(DACC_INTERFACE, out_DAC1);//write on DAC
  else if (effect==1)  // EFFECT 1: Asymmetric Distortion
    digitalWrite(LED, LOW);
   upper_threshold=map(POT0,0,4095,4095,2047);
  lower_threshold=map(POT1,0,4095,0000,2047);
  if(in_ADC0>=upper_threshold) in_ADC0=upper_threshold;
  else if(in_ADC0<lower_threshold)  in_ADC0=lower_threshold;
  if(in_ADC1>=upper_threshold) in_ADC1=upper_threshold;
  else if(in_ADC1<lower_threshold)  in_ADC1=lower_threshold;
  //adjust the volume with POT2
  //Write the DACs
    else if (effect==2) // EFFECT 2: Echo.
   //Store current readings
  sDelayBuffer0[DelayCounter]  = (in_ADC0 + (sDelayBuffer0[DelayCounter]))>>1;
  //Adjust Delay Depth based in pot0 position.
  Delay_Depth =map(POT0>>2,0,2047,1,40000);
  //Increse/reset delay counter.
  DelayCounter++;
  if(DelayCounter >= Delay_Depth) DelayCounter = 0;
  out_DAC0 = ((sDelayBuffer0[DelayCounter]));
  //Add volume feature based in POT2 position.
  out_DAC0=map(out_DAC0,0,4095,1,POT2);
  //Write the DACs
  dacc_write_conversion_data(DACC_INTERFACE, 0);          //write on DAC
  else  // EFFECT 3: Chourus
  sDelayBuffer0[DelayCounter] = in_ADC0;
  POT0=map(POT0>>2,0,1024,1,25); //25 empirically chosen
  DelayCounter++;
    DelayCounter = 0;
    if(count_up)
       for(p=0;p<POT0+1;p++)
       sDelayBuffer0[Delay_Depth+p]=sDelayBuffer0[Delay_Depth-1];
       Delay_Depth=Delay_Depth+POT0;
       if (Delay_Depth>=MAX_DELAY)count_up=0;
       Delay_Depth=Delay_Depth-POT0;
       if (Delay_Depth<=MIN_DELAY)count_up=1;
  out_DAC0 = sDelayBuffer0[DelayCounter];
  //Add volume control based in POT2
  //Write the DACs
void switch_handler()
  delayMicroseconds(100000); //debouncing protection
  if (toggle_value!=digitalRead(TOGGLE)) effect++;
  toggle_value=digitalRead(TOGGLE);
  if (effect==4) effect=0;
  Delay_Depth=300; //reset the variable.
Estos son algunos de los errores que me aparecen entre otros:
multi_effects.ino:11:36: error: size of array ‘sDelayBuffer0’ is too large
multi_effects.ino: In function ‘void setup()’:
multi_effects.ino:21:29: error: ‘pmc_set_writeprotect’ was not declared in this scope
multi_effects.ino:22:25: error: ‘ID_TC4’ was not declared in this scope
multi_effects.ino:22:31: error: ‘pmc_enable_periph_clk’ was not declared in this scope
multi_effects.ino:25:27: error: ‘TC1’ was not declared in this scope
multi_effects.ino:25:47: error: ‘TC_CMR_WAVE’ was not declared in this scope
multi_effects.ino:25:61: error: ‘TC_CMR_WAVSEL_UP_RC’ was not declared in this scope
multi_effects.ino:26:5: error: ‘TC_CMR_TCCLKS_TIMER_CLOCK2’ was not declared in this scope
multi_effects.ino:26:31: error: ‘TC_Configure’ was not declared in this scope
multi_effects.ino:27:23: error: ‘TC_SetRC’ was not declared in this scope
multi_effects.ino:30:18: error: ‘TC_Start’ was not declared in this scope
multi_effects.ino:33:29: error: ‘TC_IER_CPCS’ was not declared in this scope
multi_effects.ino:39:18: error: ‘TC4_IRQn’ was not declared in this scope
multi_effects.ino:39:26: error: ‘NVIC_EnableIRQ’ was not declared in this scope
multi_effects.ino:42:6: error: base operand of ‘->’ is not a pointer
multi_effects.ino:43:6: error: base operand of ‘->’ is not a pointer
multi_effects.ino:44:6: error: base operand of ‘->’ is not a pointer
multi_effects.ino:47:15: error: ‘DAC0’ was not declared in this scope
multi_effects.ino:48:15: error: ‘DAC1’ was not declared in this scope
multi_effects.ino: In function ‘void loop()’:
multi_effects.ino:62:13: error: base operand of ‘->’ is not a pointer
multi_effects.ino:63:14: error: base operand of ‘->’ is not a pointer
multi_effects.ino:64:14: error: base operand of ‘->’ is not a pointer
multi_effects.ino:65:11: error: base operand of ‘->’ is not a pointer
multi_effects.ino:66:11: error: base operand of ‘->’ is not a pointer
multi_effects.ino:67:11: error: base operand of ‘->’ is not a pointer
multi_effects.ino: In function ‘void TC4_Handler()’:
sin codigo nadie puede ayudarte.
saludos de alemania
Hola
Estoy haciendo un proyecto sobre un pedal con Arduino y de la pagina donde saque el
código es para Arduino Due yo estoy utilizando el Arduino Uno así que me marca esos errores. Y no
se mucho sobre la programación por lo tanto no se como resolverlos, aunque e estado buscando.
Gracias.
En el siguiente archivo esta el código.
Saludos.
multi_effects.ino (5.93 KB)
You cannot have an array of 40000 2 byte ints on an arduino
multi_effects.ino:11:36: error: size of array 'sDelayBuffer0' is too large
It means what it says.
Please edit your post, select the code, and put it between [code][/code] tags.
You can do that by hitting the “Code” icon above the posting area. It is the first icon, with the symbol: </>
Moving to Spanish section.
Ese código está específicamente diseñado para Arduino Due, y no se puede compilar en un Uno, ya que usa una característica específica del Due: los DAC
