Ayuda.... programacion rele inalambrico 4 chanel
Hola a todos alguien me podría ayudar a encontrar los errores de programación para poder usar los rele inalambricos 4 chanel, estoy ocupando arduino mega 2560, llevo meses con el drama. desde ya mucha gracias
//Author: cantone-electonics
//Arduino 1.0
//Arduino uno R3
//Making a wireless remote control with arduino
const int data_out = A0;//encoder DOUT
//LED pin,When receiving the key from the serial port, LED flash
const int ledPin = A1; //LED pin
// OSC Resistance is 3.3M
const int Osc_4xCycle = 359; //4 oscillating time periods
const int Osc_12xCycle = 1078;//12 oscillating time periods
unsigned long Temporary[3];//Temporary storage unit
//send:8 Address Bits, 4 Data Bits, Sync bit
void send_data()
// initialize the LED pin as an output:
pinMode(ledPin, OUTPUT);
// initialize the encoder DOUT pin as an output
pinMode(data_out, OUTPUT);
while(1)
//get key from pc serial port
while (Serial.available() > 0)
keydata = Serial.read();
receive_flag = 1;
delay(2);
if(receive_flag == 1)//if get key,send key
receive_flag = 0;
if((keydata == 'a') || (keydata == 'A'))//trigger A channel relay.
Temporary[2] = 0xC0;// 0xC0 is A button key
digitalWrite(ledPin, HIGH);//Turn on led
send_data();//send code word
Serial.println(".....trigger A channel relay.....");
else if((keydata == 'b') || (keydata == 'B'))//trigger B channel relay.
Temporary[2] = 0x30;// 0x30 is B button key
Serial.println(".....trigger B channel relay.....");
else if((keydata == 'c') || (keydata == 'C'))//trigger C channel relay.
Temporary[2] = 0x0C;// 0x0C is C button key
Serial.println(".....trigger C channel relay.....");
else if((keydata == 'd') || (keydata == 'D'))//trigger D channel relay.
Temporary[2] = 0x03;// 0x03 is D button key
Serial.println(".....trigger D channel relay.....");
Adjunto link del modulo:
http://www.ebay.com/itm/Dc12v-433m-Arduino-4ch-control-remoto-de-reles-inalambricos-de-Controlador-Para-Uno-Mega2560-/272177306091?hash=item3f5f0819eb&nma=true&si=6cU8tjhH5A74E6c70em4gLn2ZGU%3D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
Bueno no encuentro la librería.
Ese código además de no estar con tags, esta incompleto
La causa de la falla es que
void senddata()
asi solo no puede ir.
Debe ser minimamente así
void senddata() {}
esta vacío
Debería tener una rutina haciendo algo.
En la página del módulo (que también esta sin tag) esta muy confusa la información, asi que ya que tu eres el interesado busca la librería y un buen ejemplo de tu módulo.
receive_flag y keydata son variables que tampoco no estan.
