I have bought an Microcontroller Board AZ-ATmega328-Board and installed the driver needed for it but I still do not get any connection. The upload using the IDE is not successful. In the internet I found lots of similar problems in the comments of this product but there were no solutions provided.
I will take a SWAG and say that is a Nano with the old boot loader. Go to tools, select Nano then old boot loader. If that does not work try the other boot loader.
I´m gonna explain it. I tried to upload the simple example "Hello World" from the LCD library. First, the code is compiled. After that the upload process starts and after a few seconds it is written that "upload is done". But there no upload occured. Because there is no error message, I do not get any errors to share with you.
Please explain what you mean by the quoted text below.
How do you know?
In the IDE under preferences disable "verbose output during compilation" and enable "verbose output during upload". Perform the upload and post the results here.
Which version of the IDE are you using (I think it's 1.8.x but not sure)?
I mean that I cant see if the Arduio IDE knows that the board is connected. I can choose the COM-Port but thats all. In the 2.X version I could always see if the IDE recognise it.
Yes, I use the 1.8.19 becaus I´ve read online that it doesn´t work with the 2.X version as I already tried.
After you click "upload/=>" watch the LEDs on the Arduino... you will see activity on "L", "TX" and "Rx" (what did you observe?)
In the Serial Monitor, you will get a report (also called "error" from the old "standard error output device" meaning Serial Monitor). What is in that report (copy/paste that here).
After you click "upload/=>" watch the LEDs on the Arduino... you will see activity on "L", "TX" and "Rx" (what did you observe?) <
I see that the ON is always shining. Also L is shining. Blinking is observed at the L, RX and X1 during upload.
<In the Serial Monitor, you will get a report (also called "error" from the old "standard error output device" meaning Serial Monitor). What is in that report (copy/paste that here).>
I have a blank sheet there. No information.
This is your "Serial Monitor" tab in the bottom part of IDE. To the left of the Serial Monitor tab is the OUTPUT tab... click on that tab to observe the compile/upload/error report.
I dont know If I understand you but there is only this message downwards:
The sketch uses 1894 bytes (6%) of the programme memory. The maximum is 30720 bytes.
Global variables use 59 bytes (2%) of the dynamic memory, 1989 bytes remain for local variables. The maximum is 2048 bytes.
