[b]HELP with GSM Shield and Arduino MEGA[/b]
Hey Guys,
I’m trying to send a text message to a phone using Sparkfuns SM5100B GSM Shield. I have connected 5V, GND, Arduino PIN 19 to D2 Pin of GSM Shield, Arduino PIN 18 to D3 Pin of GSM Shield and am using the following code:
/*  Example 26.3 GSM shield sending a SMS text message
http://tronixstuff.com/tutorials > chapter 26 */
char mobilenumber[] = "6625980087";  // Replace xxxxxxxx with the recipient's mobile number
{  //Initialize serial ports for communication.
Serial1.begin(9600);
delay(35000); // give the GSM module time to initialise, locate network etc.
// this delay time varies. Use example 26.1 sketch to measure the amount
// of time from board reset to SIND: 4, then add five seconds just in case
Serial1.println("AT+CMGF=1"); // set SMS mode to text
Serial1.print("AT+CMGS=");  // now send message...
Serial1.print(34,BYTE); // ASCII equivalent of "
Serial1.print(mobilenumber);
Serial1.println(34,BYTE);  // ASCII equivalent of "
delay(500); // give the module some thinking time
Serial1.print("They call me the count... because I like to count! Ah ha ha ha");   // our message to send
Serial1.println(26,BYTE);  // ASCII equivalent of Ctrl-Z
delay(15000); // the SMS module needs time to return to OK status
do // You don't want to send out multiple SMSs.... or do you?
delay(1);
Serial.println("LOOPING");
while (1>0);
I get to see the “LOOPING” on serial terminal but never actually get the txt message… can someone tell me what I am doing wrong ? Am i connecting the shield correctly ?
