back on the HT12 project again
The Holtek HT12 is an encoder/decoder pair of chips used for many years in remote controls etc. There is an Arduino library that is for decoding the signal but I can't seem to get it to compile. I get the message below. I cannot find a "double" in the cpp file???
Any ideas?
In file included from H:\arduino\arduino-0021\arduino-0021\hardware\arduino\cores\arduino/WProgram.h:6
                from HT12example.cpp:3:
h:/arduino/arduino-0021/arduino-0021/hardware/tools/avr/lib/gcc/../../avr/includ
e/math.h:439: error: expected unqualified-id before 'double'
e/math.h:439: error: expected `)' before 'double'
Have a look here:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1285544974
It sounds like you have a "round" function or macro defined somewhere before math.h gets included and that is causing confusion.
-- The Gadget Shield: accelerometer, RGB LED, IR transmit/receive, light sensor, potentiometers, pushbuttons
Thanks for the post, I checked out the link, but I think thats a bit over my head as a newbie, I did look in the HT12 h and cpp files, but I am not sure where else to look......
Can you post the whole code somewhere? Maybe someone can spot something you haven't.
-- The Quick Shield: breakout all 28 pins to quick-connect terminals
Heres the ccp and h files with an example from the author :-
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1213063480/0
Try removing the #include "WProgram.h" line from the HT12.cpp file. That seemed to fix it in the other thread I mentioned.
Thanks a lot, I will try that today
Well its different now, after removing ( commenting out ) the "WProgram.h" line in the ccp file..... it looks like it needs something from that library too....
D:\arduino\arduino-0021\arduino-0021\hardware\arduino\cores\arduino/wiring.h: In member function 'int HT12E::read()':
D:\arduino\arduino-0021\arduino-0021\hardware\arduino\cores\arduino/wiring.h:119: error: too few arguments to function 'long unsigned int pulseIn(uint8_t, uint8_t, long unsigned int)'
D:\arduino\arduino-0021\arduino-0021\libraries\HT12E\HT12E.cpp:31: error: at this point in file
D:\arduino\arduino-0021\arduino-0021\libraries\HT12E\HT12E.cpp:60: error: at this point in file
In the ccp file there is
#include "HT12E.h"
HT12E::HT12E(int pin, unsigned int addrMask)
  _pin = pin;
  pinMode(_pin, INPUT);
  _data = 0;
  _mask = addrMask << 4;  // the HT12E basic word is a stream with an 8-bit address
                          // followed by 4-bit data. I left shift the
                          // address mask 4 bits so I can match it to the entire word
Does the HT12E::HT12E(int pin, unsigned int addrMask) look right to you guys?
