Back to the Future Clock showing the year 2165
I've built a Back to the Future clock following this website and I've uploaded the code successfully to the nano. However, the green LED should show the current date/time and its displaying 5/5/2165 with a time of 3:05am. It always shows this time. The website does show that the present time (green LED) acts like a clock and shows the present time and updates. How can I fix the code so that the green LED displays like an actual clock. Code is attached below.
#include "SevenSegmentTM1637.h"
#include "SevenSegmentExtended.h"
#include "RTClib.h"
// Sortie horloge Rouge
const byte PIN_CLK_Red = A0;   // define CLK pin
// Sortie horloge Verte
const byte PIN_CLK_Green = A1;   // define CLK pin
// Sortie horloge Orange
const byte PIN_CLK_Orange = A2;   // define CLK pin
//RED Displays
const byte PIN_DIO_R1 = 3;
SevenSegmentExtended      red1(PIN_CLK_Red, PIN_DIO_R1);
const byte PIN_DIO_R2 = 4;
SevenSegmentTM1637       red2(PIN_CLK_Red, PIN_DIO_R2);
const byte PIN_DIO_R3 = 5;
SevenSegmentExtended     red3(PIN_CLK_Red, PIN_DIO_R3);
//GREEN Displays
const byte PIN_DIO_G1 = 6;
SevenSegmentExtended      green1(PIN_CLK_Green, PIN_DIO_G1);
const byte PIN_DIO_G2 = 7;
SevenSegmentTM1637       green2(PIN_CLK_Green, PIN_DIO_G2);
const byte PIN_DIO_G3 = 8;
SevenSegmentExtended     green3(PIN_CLK_Green, PIN_DIO_G3);
int greenAM = 12;
int greenPM = 13;
// ORANGE Displays
const byte PIN_DIO_O1 = 9;   // define DIO pin (any digital pin)
SevenSegmentExtended      orange1(PIN_CLK_Orange, PIN_DIO_O1); // SegmentExtended pour utiliser la methode "PrintTime"
const byte PIN_DIO_O2 = 10;
SevenSegmentTM1637        orange2(PIN_CLK_Orange, PIN_DIO_O2); //SegmentTM1637 pour utiliser la methode "print" permet d'enlever les ":" entre les chiffres
const byte PIN_DIO_O3 = 11;
SevenSegmentExtended       orange3(PIN_CLK_Orange, PIN_DIO_O3);
bool parse = false;
bool config = false;
int Hour = 0;
RTC_DS3231 rtc;
int backlight = 50;
int year_red = 2028;
int year_orange = 2018;
  pinMode(PIN_CLK_Red, OUTPUT);
  pinMode(PIN_CLK_Green, OUTPUT);
  pinMode(PIN_CLK_Orange, OUTPUT);
  pinMode(PIN_DIO_O1, OUTPUT);
  pinMode(PIN_DIO_O2, OUTPUT);
  pinMode(PIN_DIO_O3, OUTPUT);
  pinMode(PIN_DIO_G1, OUTPUT);
  pinMode(PIN_DIO_G2, OUTPUT);
  pinMode(PIN_DIO_G3, OUTPUT);
  pinMode(PIN_DIO_R1, OUTPUT);
  pinMode(PIN_DIO_R2, OUTPUT);
  pinMode(PIN_DIO_R3, OUTPUT);
  pinMode(greenAM, OUTPUT);
  pinMode(greenPM, OUTPUT);
  Serial.begin(9600);       // initializes the Serial connection @ 9600 baud
  orange1.begin();            // initializes the display
  orange2.begin();
  orange3.begin();
  green1.begin();
  green2.begin();
  green3.begin();
  red1.begin();
  red2.begin();
  red3.begin();
  orange1.setBacklight(backlight);  // set the brightness to 100 %
  orange2.setBacklight(backlight);
  orange2.setColonOn(0); // Switch off ":" for orange "year"
  orange3.setBacklight(backlight);
  green1.setBacklight(backlight);
  green2.setBacklight(backlight);
  green3.setBacklight(backlight);
  red1.setBacklight(backlight);
  red2.setBacklight(backlight);
  red3.setBacklight(backlight);
  red2.setColonOn(0); // Switch off ":" for red "year"
#ifndef ESP8266
  while (!Serial); // for Leonardo/Micro/Zero
#endif
  delay(3000); // wait for console opening
  if (! rtc.begin()) {
    Serial.println("Couldn't find RTC");
    while (1);
  if (rtc.lostPower()) {
    Serial.println("RTC lost power, lets set the time!");
    // following line sets the RTC to the date & time this sketch was compiled
    rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
  DateTime now = rtc.now();
  //    Serial.print(now.year(), DEC);
  //    Serial.print('/');
  //    Serial.print(now.month(), DEC);
  //    Serial.print(now.day(), DEC);
  Serial.print(" ");
  Serial.print(now.hour(), DEC);
  Serial.print(':');
  Serial.print(now.minute(), DEC);
  Serial.print(':');
  Serial.print(now.second(), DEC);
  if (now.hour() == 0)
    Hour = 12;
    digitalWrite(greenAM, 1);
    digitalWrite(greenPM, 0);
    Serial.write(" =0");
  else if (now.hour() == 12)
    Hour = now.hour();
    digitalWrite(greenAM, 0);
    digitalWrite(greenPM, 1);
    Serial.write(" =12");
  else if (now.hour() >= 13) {
    Hour = now.hour() - 12;
    Serial.write(" >=13");
  else {
    Hour = now.hour();
    Serial.write("else");
  //Red displays -  Destination TIME 11.05 2028 10:04
  red1.printTime(11, 9, true);
  red2.print(year_red, true);
  red3.printTime(10, 07, true);
  //Green Displays - Present TIME - Heure actuelle
  green1.printTime(now.month(), now.day(), true);
  green2.print(now.year());
  green3.printTime(Hour, now.minute(), true);
  // Orange Displays - Last time departed 10.26 1985 01:24
  orange1.printTime(11, 9, true);
  orange2.print(year_orange, true);
  orange3.printTime(01, 24, true);
Does the serial monitor display the correct time?
This is what it is displaying.
165:165:85
=13 165:165:8RTC lost power, lets set the time!
165:165:85
=13 165:165:85
=13 165:165:85
Are you absolutely sure that isn't the correct date where you are? Are the cars flying? Has cold fusion been perfected? If so, please send me the formula via personal message, and don't tell anyone else :wink:
Do you have a button battery connected/installed in the RTC module? If so, have you tested the battery with your multimeter?
There is a button battery connected to the RTC module. I removed the battery incase it was storing the wrong time. I haven't used a multimeter on it.
Do that. It should read around 3.0~4.5V. If not, it is faulty or flat. Your RTC will definitely not give the correct time without a good battery.
So I realized that the GND had come undone. I fixed it and it is now showing the correct date/year. However, the time is still off by 6 hrs. Could there still be something wrong with the connection?
Setting the correct time should fix that. This line sets the date and time to whatever the PC internal clock is set to, when the program is compiled (which might be UTC time):
You are reading UTC.
I've uploaded the code and it doesn't match the PC internal clock when the program is compiled. On a mac, if that matters. The last two times I've compiled it, it is now 10min off. At least it isn't 6hrs. How would I adjust the (TIME) code to be the correct time? Thank you!
