Greetings,
I am a novice when it comes to coding. I have recently made a Back to the Future clock and need some help with the coding for the current time. I will provide a link to the YouTube channel where I got this idea from. The code is on Thingiverse, but will provide it here so you can take a look. The issue is that it seems that the time zone is not being set correctly. The minutes are correct, but the hours are ahead. I forgot what the total was, and I apologize for that. That is why I am thinking it is a time zone issue. I currently live in the Central time zone in the United States. Any help would be appreciated.
YouTube: Back to the Future clock - WIFI EDITION [ENG SUB] - YouTube
Code:
#include "Arduino.h"
#include "TM1637Display.h"
#include "ArduinoJson.h"
#include "WiFiManager.h"
#include "NTPClient.h"
// Module connection pins (Digital Pins)
#define red_CLK 13
#define red1_DIO 14
#define red2_DIO 15
#define red3_DIO 16
#define green_CLK 17
#define green1_DIO 18
#define green2_DIO 19
#define green3_DIO 21
#define orange_CLK 22
#define orange1_DIO 23
#define orange2_DIO 25
#define orange3_DIO 26
#define greenAM 32
#define greenPM 33
bool res;
int Hour = 0;
//========================USEFUL VARIABLES=============================
int UTC = 2; // UTC + value in hour - Summer time
const long utcOffsetInSeconds = 3600; // Offset in second
int Display_backlight = 255;
//Set the red displays
int red_day = 26;
int red_month = 10;
int red_year = 1985;
int red_hour = 9;
int red_minute = 00;
//set the orange displays
int orange_day = 12;
int orange_month = 11;
int orange_year = 1955;
int orange_hour = 06;
int orange_minute = 38;
// Define NTP Client to get time
WiFiUDP ntpUDP;
NTPClient timeClient(ntpUDP, "pool.ntp.org", utcOffsetInSeconds*UTC);
TM1637Display green1(green_CLK, green1_DIO);
TM1637Display green2(green_CLK, green2_DIO);
TM1637Display green3(green_CLK, green3_DIO);
TM1637Display red1(red_CLK, red1_DIO);
TM1637Display red2(red_CLK, red2_DIO);
TM1637Display red3(red_CLK, red3_DIO);
TM1637Display orange1(orange_CLK, orange1_DIO);
TM1637Display orange2(orange_CLK, orange2_DIO);
TM1637Display orange3(orange_CLK, orange3_DIO);
pinMode(32, OUTPUT);
pinMode(33, OUTPUT);
WiFiManager manager;
manager.setTimeout(180);
//fetches ssid and password and tries to connect, if connections succeeds it starts an access point with the name called "BTTF_CLOCK" and waits in a blocking loop for configuration
res = manager.autoConnect("BTTF_CLOCK","password");
if(!res) {
Serial.println("failed to connect and timeout occurred");
ESP.restart(); //reset and try again
timeClient.begin();
red1.setBrightness(Display_backlight);
red2.setBrightness(Display_backlight);
red3.setBrightness(Display_backlight);
green1.setBrightness(Display_backlight);
green2.setBrightness(Display_backlight);
green3.setBrightness(Display_backlight);
orange1.setBrightness(Display_backlight);
orange2.setBrightness(Display_backlight);
orange3.setBrightness(Display_backlight);
timeClient.update();
Serial.print("Time: ");
Serial.println(timeClient.getFormattedTime());
unsigned long epochTime = timeClient.getEpochTime();
struct tm *ptm = gmtime ((time_t *)&epochTime);
int currentYear = ptm->tm_year+1900;
Serial.print("Year: ");
Serial.println(currentYear);
int monthDay = ptm->tm_mday;
Serial.print("Month day: ");
Serial.println(monthDay);
int currentMonth = ptm->tm_mon+1;
Serial.print("Month: ");
Serial.println(currentMonth);
if (timeClient.getHours() == 0)
Hour = 12;
digitalWrite(greenAM, 1);
digitalWrite(greenPM, 0);
Serial.write(" =0");
else if (timeClient.getHours() == 12)
Hour = timeClient.getHours();
digitalWrite(greenAM, 0);
digitalWrite(greenPM, 1);
Serial.write(" =12");
else if (timeClient.getHours() >= 13) {
Hour = timeClient.getHours() - 12;
Serial.write(" >=13");
else {
Serial.write("else");
red1.showNumberDecEx(red_month,0b01000000,true,2,0);
red1.showNumberDecEx(red_day,0b01000000,true,2,2);
red2.showNumberDecEx(red_year,0b00000000,true);
red3.showNumberDecEx(red_hour,0b01000000,true,2,0);
red3.showNumberDecEx(red_minute,0b01000000,true,2,2);
green1.showNumberDecEx(currentMonth,0b01000000,true,2,0);
green1.showNumberDecEx(monthDay,0b01000000,true,2,2);
green2.showNumberDecEx(currentYear,0b00000000,true);
green3.showNumberDecEx(Hour,0b01000000,true,2,0);
green3.showNumberDecEx(timeClient.getMinutes(),0b01000000,true,2,2);
orange1.showNumberDecEx(orange_month,0b01000000,true,2,0);
orange1.showNumberDecEx(orange_day,0b01000000,true,2,2);
orange2.showNumberDecEx(orange_year,0b00000000,true);
orange3.showNumberDecEx(orange_hour,0b01000000,true,2,0);
orange3.showNumberDecEx(orange_minute,0b01000000,true,2,2);
if((currentMonth30 + monthDay) >= 121 && (currentMonth30 + monthDay) < 331){
timeClient.setTimeOffset(utcOffsetInSecondsUTC);} // Change daylight saving time - Summer
else {timeClient.setTimeOffset((utcOffsetInSecondsUTC) - 3600);} // Change daylight saving time - Winter
if(timeClient.getHours()>=13){
digitalWrite(greenAM,0);
digitalWrite(greenPM,1);}
else if(timeClient.getHours()==12){
else{
digitalWrite(greenAM,1);
digitalWrite(greenPM,0);}
delay(20);
