I have a 500ohm (a little high but should not matter) resistor in line from pin 12 to an LED. Why won't the LED light? My code?
pinMode(12,OUTPUT);
digitalWrite(12, HIGH);
digitalWrite(12, LOW);
Is the LED polarity correct?
Do you have a connection between the LED anode and the Arduino GND?
What Arduino board are you using?
Check your polarity. Should be to simple not to work.
Played around with polarity (all the kids do these days). Took out the resistor, worked. Put resistor in, nothing. Resistor read correctly on meter. Put it back in and it still would not let the LED come on. Weird.
You're getting around 6mA in that circuit. Is that enough for the LED?
(5v - 1.7v) / 500 = 0.0066
Or maybe you're using a 3.3V Arduino in which case you're only getting 3mA. Or maybe it's a blue LED in which you're getting almost no current.
Steve
AM I missing something here?
Your code is just in the setup?
not in the loop?
You are turning the output pin on for one second and then off forever. Try this:
pinMode(12,OUTPUT);
Or better yet, use the built-in LED on Pin 13:
pinMode(LED_BUILTIN,OUTPUT);
digitalWrite(LED_BUILTIN, HIGH);
digitalWrite(LED_BUILTIN, LOW);
