Hello,
I am struggling with some random missed or dropped packets with in my Lora code.
Board that I am using
Link
my project is
-Remotely monitor Temp, pressure, humidity, report to the receiver board.
-Receiver board- receives data and creates web page and posts Data
-OLED display-displays data after every reading
-The project is based on this tutorial.
Tutorial
Issues
-The code works and I can send and receive data most of the time
-Screen gets locked up on a old reading, when I reset the board it updates to latest packets sent.
-Randomly packets come through garbled as weird symbols on my serial monitor, this tends to result in the OLED and web server no updating or showing a garbled message. Sometimes this clears when the next a packet is sent, sometimes it is not.
Attempted so far
-I have made the OLED reset every so often- did not fix issue
-I have tried to implement code from the site below to deal with bad/missed/dropped packets
-code
-This issues seems to have made it worse and I cannot figure out where the code is getting hung up, as it seems it should work to do a oneway filter.
Any help is greatly appreciated. Please see both sender and receiver code attached.
Receiver
Rui Santos
Complete project details at https://RandomNerdTutorials.com/esp32-lora-sensor-web-server/
Permission is hereby granted, free of charge, to any person obtaining a copy
of this software and associated documentation files.
The above copyright notice and this permission notice shall be included in all
copies or substantial portions of the Software.
// Import Wi-Fi library
#include <WiFi.h>
#include "ESPAsyncWebServer.h"
#include <SPIFFS.h>
//Libraries for LoRa
#include <SPI.h>
#include <LoRa.h>
//Libraries for OLED Display
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
// Libraries to get time from NTP Server
#include <NTPClient.h>
#include <WiFiUdp.h>
//define the pins used by the LoRa transceiver module
#define SCK 5
#define MISO 19
#define MOSI 27
#define SS 18
#define RST 14
#define DIO0 26
//433E6 for Asia
//866E6 for Europe
//915E6 for North America
#define BAND 915E6
//OLED pins
#define OLED_SDA 4
#define OLED_SCL 15
#define OLED_RST 16
#define SCREEN_WIDTH 128 // OLED display width, in pixels
#define SCREEN_HEIGHT 64 // OLED display height, in pixels
#define maxPacketSize 45
#define minPacketSize 20
bool validPackage = true;
// Replace with your network credentials
const char* ssid = "SSID";
const char* password = "Password";
// globals:
// t_minutes_LastUpdate: t in minutes since system start
// as moment of last good received package
unsigned long t_minutes_LastUpdate = 0;
// help flag denotes that 1st packet had been received
bool flag1stReceived = false;
bool SisNumeric(String s) { // never negative values here
// check if s is an valid integer
for (int i = 0; i < s.length(); i++) {
if (!isDigit(s[i])) {
return false, Serial.println("BAD Numeric PACKET");
return true, Serial.println("GOOD Numeric PACKET");
bool SisFloat(String s) { // also negative floats possible
// check if s is an valid float number
bool flagDot = false;
if (s[i] != '-' || i > 0) {
if (s[i] == '.' && i > 0 && !flagDot) {
flagDot = true;
return false, Serial.print("BAD float PACKET");
return true, Serial.println("GOOD FLOAT PACKET");
// oled reset timer
const unsigned long OledResetDelay = 60000;
unsigned long OledResetTimer = 0;
// Define NTP Client to get time
WiFiUDP ntpUDP;
NTPClient timeClient(ntpUDP);
// Variables to save date and time
String formattedDate;
String day;
String hour;
String timestamp;
// Initialize variables to get and save LoRa data
int rssi;
String loRaMessage;
String bootCount;
String temperature;
String humidity;
String pressure;
String readingID;
// Create AsyncWebServer object on port 80
AsyncWebServer server(80);
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RST);
// Replaces placeholder with DHT values
String processor(const String& var){
Serial.println(var);
if(var == "TEMPERATURE"){
return temperature;
else if(var == "HUMIDITY"){
return humidity;
else if(var == "PRESSURE"){
return pressure;
else if(var == "TIMESTAMP"){
return timestamp;
else if (var == "RSSI"){
return String(rssi);
else if (var == "BOOTCOUNT") {
return bootCount;
else if (var == "READINGID") {
return readingID;
return String();
//Initialize OLED display
void startOLED(){
//reset OLED display via software
pinMode(OLED_RST, OUTPUT);
digitalWrite(OLED_RST, LOW);
delay(20);
digitalWrite(OLED_RST, HIGH);
//initialize OLED
Wire.begin(OLED_SDA, OLED_SCL);
if(!display.begin(SSD1306_SWITCHCAPVCC, 0x3c, false, false)) { // Address 0x3C for 128x32
Serial.println(F("SSD1306 allocation failed"));
for(;;); // Don't proceed, loop forever
display.clearDisplay();
display.setTextColor(WHITE);
display.setTextSize(1);
display.setCursor(0,0);
display.print("LORA SENDER");
//Initialize LoRa module
void startLoRA(){
int counter;
//SPI LoRa pins
SPI.begin(SCK, MISO, MOSI, SS);
//setup LoRa transceiver module
LoRa.setPins(SS, RST, DIO0);
while (!LoRa.begin(BAND) && counter < 10) {
Serial.print(".");
counter++;
if (counter == 10) {
// Increment readingID on every new reading
Serial.println("Starting LoRa failed!");
Serial.println("LoRa Initialization OK!");
display.setCursor(0,10);
display.print("LoRa Initializing OK!");
display.display();
delay(2000);
void connectWiFi(){
// Connect to Wi-Fi network with SSID and password
Serial.print("Connecting to ");
Serial.println(ssid);
WiFi.begin(ssid, password);
Serial.print(".");
// Print local Ip address and start web server
Serial.println("WiFi connected.");
Serial.println("IP address: ");
// Read LoRa packet and get the sensor readings
void getLoRaData() {
Serial.print("Lora packet received: ");
// Read packet
while (LoRa.available()) {
String LoRaData = LoRa.readString();
// LoRaData format: bootCount/temperature&humidity#pressure$readingID
// String example: 1/27.43&654#95.34
Serial.print(LoRaData);
// Get readingID, temperature and soil moisture
int pos1 = LoRaData.indexOf('/');
int pos2 = LoRaData.indexOf('&');
int pos3 = LoRaData.indexOf('#');
int pos4 = LoRaData.indexOf('$');
if ( pos1 == 0 || pos2 == 0 || pos3 == 0 || pos4 == 0 ||
LoRaData.length() > maxPacketSize )
{ validPackage = false, Serial.println("PACKAGE TOO LONG"); }
else if ( pos1 >= pos2 || pos2 >= pos3 || pos3 >= pos4 ||
LoRaData.length() < minPacketSize )
String bootCount = LoRaData.substring(0, pos1);
String temperature = LoRaData.substring(pos1+1, pos2);
String humidity = LoRaData.substring(pos2+1, pos3);
String pressure = LoRaData.substring(pos3+1, pos4);
String readingID = LoRaData.substring(pos4+1, LoRaData.length());
if (validPackage) {
validPackage = false;
// assume
if (SisNumeric(bootCount))
Serial.println("GOOD BOOT");
if (SisFloat(temperature))
Serial.println("GOOD TEMP");
if (SisFloat(humidity))
Serial.println("GOOD HUMD");
if (SisFloat(pressure))
Serial.println("GOOD PRESSURE");
if (SisNumeric(readingID))
// if !validPackage this package will be rejected // (not processed, so another missing sample)
if (validPackage) {
Serial.println("VALID PACKAGE is GOOD!");
// Print local IP address and start web server
//display.print("Access web server at: ");
//display.setCursor(0,30);
display.print(WiFi.localIP());
display.print("READINGS");
display.setCursor(72,10);
display.print(bootCount);
display.setCursor(0,20);
display.print("Temperature:");
display.setCursor(72,20);
display.print(temperature+"F");
display.print("Humidity:");
display.setCursor(54,30);
display.print(humidity+"%");
display.setCursor(0,40);
display.print("Pressure:");
display.setCursor(54,40);
display.print(pressure+"Pa");
display.setCursor(0,50);
display.print("# of readings");
display.setCursor(80,50);
display.print(readingID);
display.display();
// Get RSSI
rssi = LoRa.packetRssi();
Serial.print(" with RSSI ");
Serial.println(rssi);
// print bootcount
Serial.println("The boot Count is #" + bootCount);
// insert this at end of getLoRaData()
t_minutes_LastUpdate = millis() / 60000.;
Serial.println("lastUpdate #" + String(t_minutes_LastUpdate));
// Note(bug!): overflow within 49 days!
flag1stReceived = true;
// check if validPackage was bad
if (!validPackage){
Serial.println ("VALID PACKAGE IS BAD");
void OledReset(){
if (millis() - OledResetTimer > OledResetDelay) {
//// Reset OLED incase it got hung up
pinMode(OLED_RST,OUTPUT);
delay(20);
digitalWrite(OLED_RST, HIGH); // while OLED is running, must set GPIO16 in high
//display.setCursor(0, 10);
//display.print("Reset");
//display.setCursor(0, 24);
//display.print("OLED...");
//display.display();
Serial.println("rest OLED");
delay(600);
OledResetTimer = millis();
//initialize OLED
display.print("reset");
// Function to get date and time from NTPClient
void getTimeStamp() {
while(!timeClient.update()) {
timeClient.forceUpdate();
// The formattedDate comes with the following format:
// 2018-05-28T16:00:13Z
// We need to extract date and time
formattedDate = timeClient.getFormattedDate();
//Serial.println(formattedDate);
// Extract date
int splitT = formattedDate.indexOf("T");
day = formattedDate.substring(0, splitT);
Serial.println(day);
// Extract time
hour = formattedDate.substring(splitT+1, formattedDate.length()-1);
Serial.println(hour);
timestamp = day + " " + hour;
//void displayReading() {
// Initialize Serial Monitor
startOLED();
startLoRA();
connectWiFi();
if(!SPIFFS.begin(true)){
Serial.println("An Error has occurred while mounting SPIFFS");
return;
// Route for root / web page
server.on("/", HTTP_GET, [](AsyncWebServerRequest *request){
request->send(SPIFFS, "/index.html", String(), false, processor);
server.on("/temperature", HTTP_GET, [](AsyncWebServerRequest *request){
request->send_P(200, "text/plain", temperature.c_str());
server.on("/humidity", HTTP_GET, [](AsyncWebServerRequest *request){
request->send_P(200, "text/plain", humidity.c_str());
server.on("/pressure", HTTP_GET, [](AsyncWebServerRequest *request){
request->send_P(200, "text/plain", pressure.c_str());
server.on("/timestamp", HTTP_GET, [](AsyncWebServerRequest *request){
request->send_P(200, "text/plain", timestamp.c_str());
server.on("/bootCount", HTTP_GET, [](AsyncWebServerRequest *request){
request->send_P(200, "text/plain", bootCount.c_str());
server.on("/rssi", HTTP_GET, [](AsyncWebServerRequest *request){
request->send_P(200, "text/plain", String(rssi).c_str());
server.on("/winter", HTTP_GET, [](AsyncWebServerRequest *request){
request->send(SPIFFS, "/winter.jpg", "image/jpg");
// Start server
server.begin();
// Initialize a NTPClient to get time
timeClient.begin();
// Set offset time in seconds to adjust for your timezone, for example:
// GMT +1 = 3600
// GMT +8 = 28800
// GMT -1 = -3600
// GMT 0 = 0
timeClient.setTimeOffset(-14400);
// Check if there are LoRa packets available
int packetSize = LoRa.parsePacket();
if (packetSize) {
bool processPackage = true; // local flag - default true
if (flag1stReceived) { //this is to prevent small problem at startup
long unsigned t_minutes_now = millis() / 60000.;
if ((t_minutes_now - t_minutes_LastUpdate) <= .5) {
// Ignore! It's a repeat of same package
// already received and processed
processPackage = false, Serial.println("REJECTED PACKET");
Serial.println("T Minutes now #" + String(t_minutes_now));
if (processPackage) {
Serial.println("Getting Lora...");
getLoRaData();
getTimeStamp();
// logSDCard();
// getLoRaData();
// getTimeStamp();
//OledReset();
Sender
Rui Santos
#include <SPI.h>
#include <LoRa.h>
#include <Wire.h>
//Libraries for BME280
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
#define uS_TO_S_FACTOR 1000000 /* Conversion factor for micro seconds to seconds */
#define TIME_TO_SLEEP 1200/* Time ESP32 will go to sleep (in seconds) 5mins */
RTC_DATA_ATTR int bootCount = 0;
RTC_DATA_ATTR int readingID = 0;
#define SCK 5
#define MISO 19
#define MOSI 27
#define SS 18
#define RST 14
#define DIO0 26
//433E6 for Asia
//866E6 for Europe
#define BAND 915E6
//OLED pins
#define OLED_SDA 4
#define OLED_SCL 15
#define OLED_RST 16
//BME280 definition
#define SDA 21
#define SCL 13
// conCountRepeat: number of repeated sending of every package.
// undefine or set to 0 to disable repeated sending packages
#define conCountRepeat 3 // 0 => no repeat
#define conWaitRepeat 3000 // wait 3 seconds before next repeat
TwoWire I2Cone = TwoWire(1);
Adafruit_BME280 bme;
//packet counter
//int readingID = 0; // Taken care of above
int counter = 0;
String LoRaMessage = "";
float temperature = 0;
float humidity = 0;
float pressure = 0;
void startOLED(){
delay(20);
digitalWrite(OLED_RST, LOW); //turned to Low to shut of OLED while in the bee. Don't need it displaying if its covered.
//initialize OLED
/*delay(20);
delay(10);
display.print("GOING DARK");
delay(20);
Method to print the reason by which ESP32
has been awaken from sleep
void print_wakeup_reason(){
esp_sleep_wakeup_cause_t wakeup_reason;
wakeup_reason = esp_sleep_get_wakeup_cause();
switch(wakeup_reason)
case ESP_SLEEP_WAKEUP_EXT0 : Serial.println("Wakeup caused by external signal using RTC_IO"); break;
case ESP_SLEEP_WAKEUP_EXT1 : Serial.println("Wakeup caused by external signal using RTC_CNTL"); break;
case ESP_SLEEP_WAKEUP_TIMER : Serial.println("Wakeup caused by timer"); break;
case ESP_SLEEP_WAKEUP_TOUCHPAD : Serial.println("Wakeup caused by touchpad"); break;
case ESP_SLEEP_WAKEUP_ULP : Serial.println("Wakeup caused by ULP program"); break;
default : Serial.printf("Wakeup was not caused by deep sleep: %d\n",wakeup_reason); break;
void startLoRA(){
//SPI LoRa pins
Serial.print(".");
counter++;
//Increment readingID on every new reading
readingID++;
display.display();
delay(2000);
void startBME(){
I2Cone.begin(SDA, SCL, 100000);
bool status1 = bme.begin(0x76, &I2Cone);
if (!status1) {
Serial.println("Could not find a valid BME280_1 sensor, check wiring!");
while (1);
void getReadings(){
temperature = (bme.readTemperature())*1.8+32;
humidity = bme.readHumidity();
pressure = bme.readPressure() / 100.0F;
void sendReadings() {
LoRaMessage = String(bootCount) + "/" + String(temperature) + "&" + String(humidity) + "#" + String(pressure) + "$" + String(readingID);
//Send LoRa packet to receiver
LoRa.beginPacket();
LoRa.print(LoRaMessage);
LoRa.endPacket();
/*display.clearDisplay();
display.print("LoRa packet sent!");
display.print(temperature);
display.print(humidity);
display.print(pressure);
display.print("Reading #:");
display.setCursor(66,50);
Serial.print("Sending packet: ");
Serial.println(readingID);
display.display();
readingID++;
//initialize Serial Monitor
// Increment boot number and print it every boot
++bootCount;
Serial.println("Boot number: " + String(bootCount));
++readingID;
Serial.println("Reading #: " + String(readingID));
startOLED();
startBME();
startLoRA();
//Print the wakeup reason for ESP32
print_wakeup_reason();
First we configure the wake up source
We set our ESP32 to wake up every 5 seconds
esp_sleep_enable_timer_wakeup(TIME_TO_SLEEP * uS_TO_S_FACTOR);
Serial.println("Setup ESP32 to sleep for every " + String(TIME_TO_SLEEP) +
" Seconds");
startOLED();
startBME();
startLoRA();
getReadings();
sendReadings();
#if (conCountRepeat > 0)
for (int i = 1; i <= conCountRepeat; i++) {
delay(conWaitRepeat);
sendReadings(); // or repeatSendReadings(); see Note
#endif
Now that we have setup a wake cause and if needed setup the
peripherals state in deep sleep, we can now start going to
deep sleep.
In the case that no wake up sources were provided but deep
sleep was started, it will sleep forever unless hardware
reset occurs.
Serial.println("Going to sleep now");
Serial.flush();
esp_deep_sleep_start();
Serial.println("This will never be printed");
Sender
Rui Santos
#include <SPI.h>
#include <LoRa.h>
#include <Wire.h>
#define SCK 5
#define MISO 19
#define MOSI 27
#define SS 18
#define RST 14
#define DIO0 26
//433E6 for Asia
//866E6 for Europe
#define BAND 915E6
//OLED pins
#define OLED_SDA 4
#define OLED_SCL 15
#define OLED_RST 16
//BME280 definition
#define SDA 21
#define SCL 13
//packet counter
int counter = 0;
float humidity = 0;
float pressure = 0;
void startOLED(){
delay(20);
//initialize OLED
/*delay(20);
delay(10);
delay(20);
void startLoRA(){
//SPI LoRa pins
Serial.print(".");
counter++;
readingID++;
display.display();
delay(2000);
void startBME(){
if (!status1) {
while (1);
void getReadings(){
LoRa.beginPacket();
LoRa.endPacket();
display.display();
readingID++;
++bootCount;
++readingID;
startOLED();
startBME();
startLoRA();
" Seconds");
startOLED();
startBME();
startLoRA();
getReadings();
sendReadings();
#endif
deep sleep.
reset occurs.
Serial.flush();
