Then thought why not a couple of transistors! So I went searching and found this (attached) the emitters voltage will be that of the base pin - foward voltage drop, I can't see this working but I'll build it and see for myself!
I plucked a figure from the air of 10mv pp... then began to amplify it using transistors, fat chance that circuit will work with such a small voltage.. unless of course a reverse diode produced > 10mv eg if 100mv up to a volt can be produced then sure..
After some experimenting I came up with this which amplifies s 10mv signal.
A (reverse-biased) photodiode passes current - not the same as a photovoltaic generating a voltage - when illuminated. The transistor amplifies that current. What is the problem (apart perhaps from lack of current gain)?
Yes lack of current gain....
I spent ages looking for the kind of voltages produced by an ir receiver when detecting an ir signal... it could be 1 or 1000mv for all I know so I started tryinh to amp a 10mv pp signal...
This blog post may be of interest: Poor maker’s Infrared receiver #2
Note: Using an IR LED, which are typically fast switching (~ns) you should be able to capture the full modulated IR signal.
However, if you use an IR phototransistor, which typically have slower rise/fall times, you should get the demodulated IR signal passing thru (based on some recent tests).
Photo diodes are often used in reverse biased mode, where IR radiation causes
current flow - voltage is irrelevant, as you feed the current into a current->voltage
conversion circuit such as common-base BJT or opamp or specialised photo-detector
IC.
This is the most sensitive and fast method of using photodiodes, and the output is
linear in the radiation intensity too.
Don Lancaster ( www.tinaja.com ) won a patent lawsuit against Bell Labs over the use of an LED as both a transmitter and a receiver for use in fiber optic lines.
Phototransistors are bad news with fast signals. A PIN photodiode or an IR LED work much better.
