I have a board with ~4 I2C devices on it and it was working just fine with code and everything.
I soldered another I2C device on than the whole chip completely froze, stalled in setup(). I removed the chip but the problem stayed, but if I remove all I2C code the rest of the program works, and I could always re-program via USB no issue.
With I2C disabled, I determined that the SDA line was only 1.2V, but after some re-work and testing it suddenly switched to the SCL line, than some time later they both when to 0.5V . Something is pulling the pins low but its not obvious why.
Do you think the I2C port is damaged?
