Bad IR reading when using analogWrite
Hi all,
I am making a project with arduino nano. I have connected two servos to pins 5 and 6 and I control them using analogWrite (they are continuous rotation so I don't need to use the Servo library or so). I have algo an IR sensor on pin 11. The problem is that the readings from the IR senses (using the IRRemote library) are good but when the servos are moving I can't get good readings from the IR sensor. While the servos are moving I get a lot of bad readings and only one or two good readings.
Why is happening this? Perhaps a conflict with timers? I also test to connect the IR sensor to pin 4 but this way the servos doesn't work well.
How can I get good reading from the IR when the servos are running?
Thanks in advance! --ugo
Hard to say anything without any code or even a photo of what you have made.
Are you powering the Servos from a separate power supply? If not, that would be the first thing to try.
marco_c:
Hi marco_c, I am powering the servos directly from a 4xAA battery pack. This battery pack is connected to an stepper-up (because 4xAA=6V and seem too low to power an arduino) and the stepper-up powers the arduino.
I have made an example code. That is:
#include <IRremote.h>
//#include <NewPing.h>
//#include <toneAC.h>
#define TRIGGER_PIN  7
#define ECHO_PIN     8
#define MAX_DISTANCE 200
#define IR_PIN 11
#define REMOTE_FORWARD    3838214000
#define REMOTE_BACKWARD   4109411888
#define REMOTE_LEFT       2718175436
#define REMOTE_RIGHT      274564916
#define REMOTE_STOP       4291178960
//NewPing sonar(TRIGGER_PIN, ECHO_PIN, MAX_DISTANCE);
IRrecv irrecv(IR_PIN);
decode_results results;
  irrecv.enableIRIn();
  //analogWrite(5,1);
  //analogWrite(6,254);
  if (irrecv.decode(&results))
    Serial.println(results.value);
    irrecv.resume(); // Receive the next value
If I comment the “analogWrite” lines the codes I received from the IR are good. But when I turn on both motors I get a lot of bad readings until I get one good signal. If I run the code only with one motor it seems to get less glitches in the signal I received from the IR.
I think that it could be noise generated when the motors are running. Could be necessary some decoupling capacitors to filter these glitches?
Thanks again,
–ugo
I think you need a better power supply than you have. You can try some capacitors on the motor terminals but in the end I don't think that 4 AA batteries will do the job properly.
Are you powering the motors directly from the Arduino pins? This is also probably not a good idea and you should use the Arduino pin to turn on the power for the motors using a transistor as a switch.
Motor tend to inject a lot of noise into the power supply, and a "stepper upper" (a boost regulator) can't eliminate it.
IR sensors are very noise sensitive, so you need a good, quiet power supply for the Arduino and IR. A separate battery powered supply would be best.
Marco_c, I am not powering the motors from the arduino pins. My motors are servos (hacked to continuous rotation) and are powered directly from the AAx4 pack.
Jreminton, I think that a separate battery would be the best too. But my project is a little robot and I don’t have space inside the body to use another battery.
There is no way to eliminate the noise?
Thanks again!
We don't know its noise, it could easily be drop-outs due to inadequate power. That is solved by using a better power source or separate power sources.
