Baffled but solved quickly - amazing help!
 Hi, I simply tried to insert a for loop to run the loop and then stop. The compiler says:
expected "(" before numeric constant and highlights the code at "for" below.
Any geniuses out there to help me? Thanks.
  pinMode(LED_BUILTIN, OUTPUT);
  digitalWrite(LED_BUILTIN, HIGH);   // turn the LED on (HIGH is the voltage level)
  delay(1500);                       // wait for a second
  digitalWrite(LED_BUILTIN, LOW);    // turn the LED off by making the voltage LOW
  delay(2000);        // wait for a second
  for (int Count = 1; Count > 16; Count++1;)
    delay(600);                       // wait for a second
    delay(300);                       // wait for a second
for (int Count = 1; Count > 16; Count++1;) . <<<<<<what's that '1' and that last semicolon doing there?
You probably want to turn around the operator in the stop condition as well.
It should look like this:
for (int Count = 1; Count < 16; Count++)
That will loop until Count is 16, starting at one and increasing by one with every loop.
Thanks BL, I thought it would be blindingly obvious to a genius. Just getting back into coding after about 12 years off.
Thanks JN, forgot to change that, was trying something else.
