Hello people I'm relatively new to arduino and I'm stuck trying to figure out how to get started with the software. For my project I am required to convert an R/C PWM output into an Analog Voltage High.
To achieve this, I have planned to use the Arduino Mini Pro but due to a lack of resources I was only able to obtain the Bai Te Mini Pro which is a cheap imitation.
I have found some info regarding how to set up the ports, drivers as well as compatibility in the arduino software so that shouldn't be the problem. I have connected the pins correctly and even set up an 0.1uF capacitor for the reset.
When I run a simple code just to see if there's an output I get an error message saying it is not in sync, I don't quite get the error message and I have been unable to trouble shoot this issue. Does anyone have any tips, remedies or guideline threads that I can make use of? Any help is greatly appreciated.
If you guys have a sample code for me to test that would be excellent as well as I'm quite new to coding too so I might potentially typed a wrong code to get started.
