Hi.
Here is the rest of the sketch.
Sorry but what are code tags.
|| This program is only for use with BALLY Bingo Backglass simulation by Joop.
|| The Bally bingo has a seperate switch which is attached to an input pin
|| to cater for the 25 holes
// Table containing numbered hole codes for JR’s simulation
char Ballcodes [26] =
{’ ',‘A’,‘B’,‘C’,‘D’,‘E’,‘F’,‘G’,‘H’,‘I’,‘J’,
‘K’,‘L’,‘M’,‘N’,‘O’,‘P’,‘Q’,‘R’,‘S’,‘T’,‘U’,‘V’,‘W’,‘X’,‘Y’};
int BallsinPocket [26]; // slots 0 and 26 are not used
int sensorvalue;
char ch; // characters from Backglass
char ch1; // characters from button processor
Serial.begin (9600);
Serial3.begin (9600);
//Set up the ARDUINO MEGA Pins
pinMode(2, INPUT_PULLUP); // YELLOW rollover
pinMode(3, INPUT_PULLUP); // RED rollover
pinMode(4, OUTPUT); // sets pin for YELLOW lamp output
pinMode(5, OUTPUT); // sets pin for RED lamp output
pinMode(A0,INPUT_PULLUP); // Ball thro gate
pinMode(A1,INPUT_PULLUP); // Ball return
pinMode(A8,INPUT_PULLUP); // Red New Game Button
pinMode(A9,INPUT_PULLUP); // Yellow Extra Ball Button
// Setup numbers 1 to 25 on pins 22 to 47 inclusive
for (int i=22; i <= 47; i++)
pinMode( i, INPUT_PULLUP);
// Check for ball thro gate
sensorvalue = digitalRead(A0);
if (sensorvalue == LOW)
Serial.print (“z”);
delay(2000);
// Check for ball return
sensorvalue = digitalRead(A1);
Serial.print (“Z”);
delay (2000);
// Check if Red Button pressed for new game
sensorvalue = digitalRead(A8);
Serial.print (“n”);
delay (500);
Serial.print ("^");
delay (500);
for ( int i=1; i<26; i++)
BallsinPocket = 0;
Serial.print ("^");*
// Check if YELLOW button pressed for extra ball
sensorvalue = digitalRead(A9);*
if (sensorvalue == LOW)*
Serial.print (“x”);*
delay (500);*
// read input from Slave UNO (Buttons)*
if (Serial3.available()>0) *
ch1 = Serial3.read();*
Serial.print (ch1);*
delay (500);*
//Process commands from backglass*
if (Serial.available()>0) *
ch = Serial.read();*
Serial3.print (ch); //pass on to UNO*
// Check for Yellow Red lights ON or OFF*
// 7 Yellow ON 6 Yellow OFF*
// 5 Red ON 4 Red OFF*
if (ch == ‘7’ )*
digitalWrite(4, HIGH);*
ch=’ ';*
if (ch == ‘6’ )*
digitalWrite(4, LOW);*
ch=’ ';*
if (ch == ‘5’ ) {*
digitalWrite(5, HIGH);*
ch=’ ';*
if (ch == ‘4’ )*
digitalWrite(5, LOW);*
ch=’ ';*
// check for ball over YELLOW rollover
sensorvalue = digitalRead(2);*
if (sensorvalue == 0)*
Serial.print (“8”); *
// check for ball over RED rollover
sensorvalue = digitalRead(3);*
Serial.print (“9”); *
*// check for ball in numbered hole *
for (int i=22; i <= 47; i++)*
int sensorvalue = digitalRead(i); *
if ((sensorvalue) == LOW && (BallsinPocket [i-21]) == LOW)*
BallsinPocket [i-21] = 1;*
Serial.print(Ballcodes [i-21]);*
delay (250); *
delay (500);*
