alright, theres no way i can be screwing this up, the motor controller im using blinks quickly but does pause for a spit second, so i think i might have this a little correct.
(yes this is the sweep servo sample code modified to use the banebots motor controller)
#include <Servo.h>
Servo myservo; // create servo object to control a servo
// a maximum of eight servo objects can be created
int pos = 0; // variable to store the servo position
pinMode(9, OUTPUT);
myservo.attach(9,1000,2000); // attaches the servo on pin 9 to the servo object
for(pos = 0; pos < 180; pos += 1) // goes from 0 degrees to 180 degrees
{ // in steps of 1 degree
myservo.write(pos); // tell servo to go to position in variable 'pos'
delay(15); // waits 15ms for the servo to reach the position
for(pos = 180; pos>=1; pos-=1) // goes from 180 degrees to 0 degrees
I don't see any info on what the "SIG" line is supposed to look like.
Presumably this is an RC thing where 20mS pulses come out for neutral position for example and less than 20mS moves one direction and more than 20mS moves the other direction?
What does the 1000, 2000, do here?
What are you seeing compared to this paragraph from the controller spec?
"The controller will activate after power is applied when neutral throttle position signals are received.
This is a built-in safety feature.
The READY LED will blink rapidly until these signals are received.
When the controller has received these neutral position signals, the READY LED will stay on continuously.
The DIR LEDs will activate individually depending on the motor direction."
So it sounds like it is not seeing a good pulse stream.
Can you revise your code to just have it stay in one position, see if you can get that steady light, then try adding movement commands after that?
and now its stable and i get full range, i still don't know why i had this problem in the first place, but now i have a benchmark of getting the stupid motor to work.
