Is there a way to take text input from a barcode scanner process it with the Arduino and then save it to a text file on a SD card and display it one line per scan in a txt file in the SD card. I want to be able to scan text with the barcode scanner so I can then later put the sd card in a card reader and read the scans line by line. I am using Arduino MEGA with USB HOST. As both the devices SD card and Barcode snanner work on SPI communication, is there a way to communicate both devices together.
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html.
Have you googled arduino spi multi slave
Tom...
