Barcode scanner + HC-05 bluetooth module not working together
I am currently trying to combine a barcode scanner and the HC-05 bluetooth module to send data to my phone.
I have both parts working independently, however when I try to put them together I have a problem.
I have the barcode scanner set up so, that it wakes when I press a button.
As soon as I press the button, the HC-05 bluetooth module (using 3.3 V) will simply turn off and stay off until I reset the power source.
I also tried this with an HC-06 with the same result. (Except that this one turns on again after a few seconds but only into pairing mode)
I have also tried it on both an arduino Nano and an arduino Uno without success.
The barcode scanner is using 0.3 mA in sleep mode and <90 mA in operating mode. (Using 3.3 V)
Am I doing something wrong? What could be the issue here?
I have the feeling it is the change in current from the barcode scanner that turns the HC-05 module off. But I am not sure how to fix this.
Any ideas?
A schematic of your connections and the code that fails would help us to help you. Otherwise we waste time guessing. What is the power source?
Here the code I am currently using (with the HC-05 connected to pin 0 and 1).
#include <SoftwareSerial.h>
const int interruptPin  = 2;
bool barCodeScannedFlag = false;
SoftwareSerial barCodeSerial(8, 7); // RX, TX
void setup(){
	barCodeSerial.begin(9600);
	pinMode(interruptPin, INPUT);
  attachInterrupt(digitalPinToInterrupt(interruptPin), barCordScanned, FALLING);
void loop(){
	if (barCodeSerial.available()) {
    Serial.write(barCodeSerial.read());
	if(barCodeScannedFlag){
void barCordScanned(){
	if(!barCodeScannedFlag)  barCodeScannedFlag = true;
Alternatively I tried connecting it to the digitial pins with Software serial with the same problem.
SoftwareSerial BTSerial(10, 11);
BTSerial.begin(9600);
BTSerial.print(sensor_result);
Again, both - the scanner and the HC-05 module work fine when I don't hook them up together.
Even if I have the barcode scanner in sleepmode connected together with the HC-05 I am able to connect it to my phone. Only when I press the button the HC-05 module will turn off.
Any ideas what might be the issue? And how to fix it?
I have the feeling it might be the current spike from 0.3 mA to <90 mA that triggers the shutdown? (The arduino nano stays on, only the HC-05 module turns off)
Or could it be an issue in the code? Maybe
attachInterrupt
