Hello all,
I have a problem with my coding i can't get to work.
I'm making a barcode scanner to count the inventory in our stores.
I got everything to work except for the barcode that is read to send to the Nextion.
I see the barcode coming in on the serial monitor, and it is sending the code to the t2.txt, but it doesn't appear on the Nextion.
If i get rid of the barcode coding in the loop and just send a text in the loop it does work.
Is there anyone that knows what I'm doing wrong?
Here is the code:
#include <SoftwareSerial.h>
#include <Nextion.h>
#include <SPI.h>
#include <SD.h>
SoftwareSerial Barcode(5, 6); // RX, TX
NexText t0 = NexText(1, 4, "t0"); // Text box added, so we can read it
NexText t2 = NexText(1, 15, "t2"); // Text box added, so we can read it
NexButton b0 = NexButton(1, 2, "b0"); // Button added
// End of declaring objects
File myFile;
char buffer[100] = {0}; // This is needed only if you are going to receive a text from the display. You can remove it otherwise.
// Further on this sketch I do receive text so that's why I created this buffer.
NexTouch *nex_listen_list[] =
&b0, // Button added
NULL // String terminated
}; // End of touch event list
void b0PushCallback(void *ptr) // Press event for "Send" button on page 2
memset(buffer, 0, sizeof(buffer)); // Clear the buffer, so we can start using it
t2.getText(buffer, sizeof(buffer)); // Read the text on the object t0 and store it on the buffer
myFile = SD.open("test.txt", FILE_WRITE);
if (myFile) {
Serial.print("Writing to test.txt...");
myFile.print(buffer); // This is the text you want to send to that object and atribute mentioned before.
Serial.write(0xff); // We always have to send this three lines after each command sent to the nextion display.
Serial.write(0xff);
Serial.write(0xff);
myFile.print(",");
t0.getText(buffer, sizeof(buffer)); // Read the text on the object t0 and store it on the buffer
myFile.println(buffer); // This is the text you want to send to that object and atribute mentioned before.
Serial.write(0xff);
Serial.write(0xff);
myFile.close();
// Send a text to the object called t2:
Serial.print("t2.txt="); // This is sent to the nextion display to set what object name (before the dot) and what atribute (after the dot) are you going to change.
Serial.print("\""); // Since we are sending text, and not a number, we need to send double quote before and after the actual text.
Serial.print("opgeslagen"); // This is the text you want to send to that object and atribute mentioned before.
Serial.write(0xff);
Serial.write(0xff);
delay (1500);
Serial.print("apparaat"); // This is the text you want to send to that object and atribute mentioned before.
Serial.write(0xff);
Serial.write(0xff);
// if the file didn't open, print an error:
Serial.print("Fout bij opslaan"); // This is the text you want to send to that object and atribute mentioned before.
Serial.write(0xff);
Serial.write(0xff);
void setup() { // Put your setup code here, to run once:
Serial.begin(9600); // Start serial comunication at baud=9600
Barcode.begin(9600); // set the data rate for the SoftwareSerial port
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print("Initializing SD card...");
if (!SD.begin(4)) {
Serial.println("initialization failed!");
while (1);
Serial.println("initialization done.");
// Register the event callback functions of each touch event:
b0.attachPush(b0PushCallback); // Button press
// End of registering the event callback functions
} // End of setup
void loop() { // Put your main code here, to run repeatedly:
nexLoop(nex_listen_list); // Check for any touch event
if(Barcode.available()) // Check if there is Incoming Data in the Serial Buffer.
// count = 0; // Reset count to zero
char myBarcode[80]; // large enough for the biggest barcode you will read
int idx = 0;
while (Barcode.available()) // Keep reading Byte by Byte from the Buffer till the Buffer is empty
char input = Barcode.read(); // Read 1 Byte of data and store it in a character variable
Serial.print(input); // Print the Byte
myBarcode[idx++] = input; // save data
delay(5); // A small delay
myBarcode[idx] = '\0'; // terminate string
Serial.print(myBarcode); // This is the text you want to send to that object and atribute mentioned before.
Serial.write(0xff);
Serial.write(0xff);
} // End of loop
