Í'm getting verification mismatches when uploading from the Arduino GUI (1.6.12) but uploading from the command line with AVRDUDE runs flawless (on the same .hex file).
- Programmer: Tinyloadr (usbtiny compatible)
- ATmega328p loaded on the programmer (it as a zif socket). Project connected with wires from breadboard
- Using James Sleeman's libraries for mega8/168/328 etc
- ATmega8 programming runs withour error from the gui (due to RAM size, I am not able to use this one for my project)
- ATmega328p gives verification errors (first mismatch at byte 0x0100 0x56 != 0x5e)
- Running AVRdude with the -e parameter runs without error
Now I read an awful lot about the Arduino parameters and I tried to change them in the PROGRAMMERS.TXT file:
usbtinyisp.name=DIY ATmega: USBtinyISP
usbtinyisp.protocol=usbtiny
usbtinyisp.program.tool=avrdude
usbtinyisp.program.extra_params=-e
I even found PROGRAMMERS.TXT in a personal tree:
C:\Users\[user]\AppData\Local\Arduino15\packages\diy_atmega8_series\hardware\avr\2016.7.21
Are there any other options to try?
