Hi all.
I have designed a custom pcb and have made a prototype currently an Arduino Mega to test ( it was designed using an ATMEGA pin layout to connect with the rest of the board so had to desolder the header pins and solder the mega to the custom pcb which was a little bit of work to desolder all the pins and add it to the new board.
I am now at a stage where it all works well and i got the main prototype done but i need to get the boards produced as an assembled unit now without the Arduino mega so i can cut out my labor time assembling each board and reduce size so basically need to design a bare bones Mega.
I need to include a usb interface on the board still ( to be able to update as software updates or future bugs are solved and make it easy to just plug in via usb to the board i don't want to have headers and another tool to do this as each board needs to have what is required on board)
I have seen a few bare atmega designs but they all use an external header to usb of some kind which i don't want to have to include a separate programmer board or anything in the finished product just a usb cable ideally.
Does anyone know where i start with this or where i can find this information out?
Thanks,
Darcy
