Hello, first time here...
I have a Bare Conductive Touch Board which I can add sounds to and trigger fine, so all appears well so-far. I'm running it on a macbook pro 2016, OS Sierra 10.12.2
I am attempting to work with proximity sensor and have started with the sketchbook 'Proximity_MP3'. However, when uploading I get a run of console errors relating to serial port. I have tried each of the 3 ports listed, each with the same fail result - the ports available are:
- /dev/cu.lpss-serial1
- /dev/cu.lpss-serial2
- /dev/cu.Bluetooth-Incoming-Port
Below is a dump of the relevant error code which is highlighted red. All other code is white and presumably fine, and there's too much to copy here.
Any advice would be much appreciated.
... Archiving built core (caching) in: /var/folders/yl/0pq0rld55g3ccclssrv41mdw0000gn/T/arduino_cache_843272/core/core_bare-conductive-arduino_avr_baretouch_51f02b7210b938436b779d1c032618e1.a
avrdude: Version 6.3, compiled on Jan 17 2017 at 12:01:35
Copyright (c) 2007-2014 Joerg Wunsch
System wide configuration file is "/Applications/Arduino.app/Contents/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/slawa/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : /dev/cu.lpss-serial1
Using Programmer : avr109
Overriding Baud Rate : 57600
AVR Part : ATmega32U4
Chip Erase delay : 9000 us
PAGEL : PD7
BS2 : PA0
RESET disposition : dedicated
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 20 4 0 no 1024 4 0 9000 9000 0x00 0x00
flash 65 6 128 0 yes 32768 128 256 4500 4500 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 1 0 0 0 0 0x00 0x00
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
Programmer Type : butterfly
Description : Atmel AppNote AVR109 Boot Loader
Connecting to programmer: .avrdude: butterfly_recv(): programmer is not responding
Found programmer: Id = ""; type = (
Software Version = .�; Hardware Version = .
avrdude: error: buffered memory access not supported. Maybe it isn't
a butterfly/AVR109 but a AVR910 device?
avrdude: initialization failed, rc=-1
Double check connections and try again, or use -F to override
this check.
avrdude: error: programmer did not respond to command: leave prog mode
avrdude: error: programmer did not respond to command: exit bootloader
avrdude done. Thank you.
the selected serial port
does not exist or your board is not connected
Thanks in advance.
