I am using arduino uno R3 & v1.6.5
Now I have programmed my code into it & want to move to board. I have made a mare minimum circuit which i need so that programmed MCU can run as it was on uno board. It is attached.
I don’t need reset switch.
Will use inductor in case I have analog function.
Need to use external osc as in uno board.
Circuit has to work with +5V. -
I have also left a ISCP header with jumpers in case it is required.
Can I program new microcontroller in the actual circuit only instead of first putting in uno board & then put back in circuit.
I have left ISCP connector for this purpose only, but how to use it?
Design1.pdf (28 KB)
