bareconductive touchboard - wifi - mqtt
Hi there,
i want to use the touchboard (leonardo based) with a (preferably) wifi shield. as their compatibility sheet seems a little bit outdated, i am asking here if
someone can help with identifiing the correct wifi - shield (one that works with one of those mqtt libraries) for this board.
many thanks
swe
A wifi module must not necessarily be a shield. Use a breakout module to avoid incompatibilities with shields.
Thanks a lot MrDiettrich, i did not think of this.
So maybe Adafruit HUZZAH ESP826 Breakout Board | EXP Tech helps then. still need to check how this would be connected.
yours
swe
