Looking for advice for a proof of concept.
We have a product line that has an hydraulic cylinder that we will attach a distance measuring sensor. (0 - 5vdc)
I want to display this on three parallel WS2811 strips so it has 10 Segments 3 leds wide to display to the operator the position of the hydraulic cylinder. Also it has to have a relay or P Channel Mosfet/BJT to power a coil on a hydraulic valve cartridge when it reaches a certain analog value. And a weather proof way to place the unit in a calibration mode to map the sensor value to 0 - 100. I'm thinking of a reed switch using a magnet.
Bonus would be to communicate via Bluetooth LE to our app to provide the analog value to enhance its features.
BLE integration would be done with professional help and later ![]()
This would be a proof of concept and will receive a custom PCB if successful.
Some of the questions I have:
Does the WS2811 max out at 12VDC or can they be driven with 13.8 - 14.8 VDC (like automotive voltage)?
If not what is the best way to buck down that low voltage. Efficiency is not critical as I have 25amp voltage source.
What size Mosfet/BJT would I need to not require a heat sink as this will be incased in clear epoxy for weatherproofing? The coil draws 2.5 amps at 12VDC.
What is a common BLE module you have had success with?
Could this be driven with an ATTINY84 or would you recommend a different MCU? I need 1 ADC, 1 Digital input for the calibration button, 1 digital output for Relay/Mosfet Control.
I can do a lot of this with parts I have, but I want to make sure I can keep the footprint small and cost down when/if it goes to production.
Just planning ahead to get some initial costing done.
Also where are some good tutorials on Kicad? I'm learning a decent amount and had experience in High School with board layout but that was a lifetime ago.
