basic authentication problem domoticz and nodemcu v3
Hello!
I need your help with a project of mine:
the server is domoticz ( using basic authentication with user:111 and pass:111) - installed on windows 10
the ip address is: 192.168.2.122 and port 8080.
if i use this link in browser all work perfect : 111:111@192.168.2.122:8080/json.htm?type=command&param=udevice&idx=3&nvalue=0&svalue=79
i tried this code, on nodemcu v3 ( the base64 library didn`t work so i use the conversion for user and password)
#include <ESP8266WiFi.h>
#include <Base64.h>
const char* ssid = “*****”;
const char* password = “*****”;
char uname[] = “111:111”;
char unameenc[40];
_const char* host = “192.168.2.122”; _
const int httpPort = 8080;
  • Serial.begin(115200);*
  • delay(10);*
  • WiFi.begin(ssid, password);*
  • WiFiClient client;*
  • if (!client.connect(host, httpPort)) {*
  • Serial.println(“connection failed”);*
  • setup();*
  • String url = “/json.htm?type=command&param=udevice&idx=3&nvalue=0&svalue=29”;*
  • client.print(String("POST “) + url + " HTTP/1.1\r\n” +*
  • "Host: " + host + “\r\n” +*
  • “Connection: close\r\n” +*
  • “Authorization: Basic " + “MTExOjExMQ==” + " \r\n” +*
  • “Content-Length: 0\r\n” +*
  • “\r\n”*
  • delay(10);*
this is the output of nodemcu:
connecting to 192.168.2.122
Requesting URL: /json.htm?type=command&param=udevice&idx=3&nvalue=0&svalue=29
closing connection
this is the imput of domoticz:
Failed authentication attempt domoticz
Any ideas? tx a lot
