Ive been playing around for a while, trying to control an DC Motor with an H-Bridge, but it doesnt seem to work at all. What am I doing wrong? A Picture of the circuit is attached and i wrote this:
int motor_A=6;
int motor_B=3;
int motor_Speed=5;
pinMode(motor_A,OUTPUT);
pinMode(motor_B,OUTPUT);
//edit
pinMode(motor_Speed,OUTPUT); //why is this not done in tutorials? Anyway, sadly it doesn't work with or without
void loop(){
digitalWrite(motor_A,HIGH);
digitalWrite(motor_B,LOW);
analogWrite(motor_Speed,255);
analogWrite(motor_Speed,0);
![Circuit_nv[1].jpg](https://europe1.discourse-cdn.com/arduino/original/3X/4/5/45d1c71b2cee0f5cc8a51b0cff07d7b9681c2189.jpg)
Lichtbruno:
int motor_A=6;
int motor_B=3;
int motor_Speed=5;
void setup(){
void loop(){
I do think that the error occur because you don't declare the pinMode for motor_Speed pin. Try to include pinMode(motor_Speed, OUTPUT).
Thanks.
Vincent19:
Yes I was wondering why, in the tutorials i could find, they don't declare the enable Pin as an output...
I tried it already and it didn't work :(. Still no movement. Thanks though :).
just figured out the problem. The H Bridge doesnt fit well, I have to press it down on the Breadboard to get the motor running. Fail.
Vincent19:
Thanks.
From this link to the reference page:
"You do not need to call pinMode() to set the pin as an output before calling analogWrite(). "
