So I've just gotten my Ethernet shield, and have not been able to use it as a client for the last 2 days...It simply won't connect to any IP, I have tried seemingly all different combinations of code...
Hardware : simple ethernet cable into the shield, mounted onto arduino. I'm using USB as a power source.
Software :
byte mac[] = { 0x00, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
byte ip[] = { 192, 168, 2, 177 };
Ethernet.begin(mac, ip);
does not work, just like
byte gateway[] = { 192, 168, 2, 1 };
byte subnet[] = { 255, 255, 255, 0 };
Ethernet.begin(mac, ip, gateway, subnet);
...return a failed connection. I pinged the IP, and have no problem there, it's not taken.
The last thing I am suspicious of...I'm working on this through school, which means that I am connection through (probably) a giant hub of some sort, and do not have access to the 'actual' router I'm connecting to. Any chance this has to do with it? These big institutions usually have a bunch of firewalls, filters, etc...Could it affect my connectivity?
Thanks
